How do you solve a nonlinear recurrence relation?
6 replies · 4K views · last reply
lugita15
While solving a problem involving equilibrium positions of charges on a line, I came up with a recurrence relation which is nonlinear, and moreover implicitly defined. Here it is: [itex]x_{0}=0[/itex] and [itex]\sum^{n-1}_{i=0} \frac{1}{(x_{n}-x_{i})^{2}} = 1[/itex]. I should also mention that [itex]0 \leq x_{n}< x_{n+1}[/itex] for all [itex]n[/itex].
I can't even find an explicit expression for [itex]x_{n}[/itex] as a function of the previous terms, let alone as a function of [itex]n[/itex]. I've dealt with linear recurrences before, but how would I go about solving a nonlinear recurrence like this? Is it even possible to find a closed-form expression using elementary functions? If an exact solution is impossible, is there some way to get a numerical approximation?
Any help would be greatly appreciated.
Thank You in Advance.
Numerical and graphical solutions. "nonlinear dynamics and chaos" is an excellent book by Strogatz that outlines such methods.
What you have is a statement about the field in integral (sum) form. Write it as a differential equation which will become a difference equation. Then you're home free linear or not.
How exactly would I "write it as a differential equation which will become a difference equation"?
OK, I have two additional facts: [itex]x_{n}\geq n[/itex] for all [itex]n[/itex] and [itex]lim_{n\rightarrow\infty} (x_{n}-x_{n-1}) = \infty[/itex]
I don't know how much they'll help.
The steady-state solution to many charge and current flow problems can be formulated as solution to Laplace's equation. That in turn is a differential operator that can be interpreted as an averaging operation. This is essentially a differencing operation between the function at a point and the average of it's neighboring values. Once you cast your problem in this form, iteration leads to the correct solution.
