How Do You Solve an Annuity Differential Equation?
4 replies · 3K views · last reply
_N3WTON_
Solve the annuity problem:
[itex]\frac{dS}{dt} = rS + d[/itex]
[itex]S(0) = S_0[/itex]
Integrating factor method equation
Future value of an annuity equation (this should be the final answer):
[itex]S(t) = S_0e^{rt} + \frac{d}{r}(e^{rt} - 1)[/itex]
Ok, I am getting quite close to doing this derivation correctly. However, I keep ending up with a negative that should not be there.
First, I set:
[itex]p(x) = -r[/itex]
Then:
[itex]u(x) = e^{-rt}[/itex]
This means that I need to take the integral of:
[itex]\frac{d}{dt} (e^{-rt}S(t)) = de^{-rt}[/itex]
After taking the integral of both sides I end up with:
[itex](e^{-rt} * S(t)) = - \frac{d}{r} e^{-rt} + C[/itex]
Therefore:
[itex]S(t) = - \frac{d}{r} + Ce^{rt}[/itex]
At this point I am not sure what to do because I believe that the negative symbol should not be there. If somebody could point out where my mistake is I would greatly appreciate it.
_N3WTON_ said:
At this point I am not sure what to do because I believe that the negative symbol should not be there...
Why? Your answer seems to agree with ##
## if ##C=S_0+\frac{d}{r}##.
ok I see it now, I guess I am just an idiot XD ...sorry for the waste of time, I forgot to do the initial value portion of the problem
_N3WTON_,
It's a good habit to get into to check a solution you get. If the solution you get 1) satisfies the initial condition, and 2) satisfies the differential equation, you're golden. You don't need us to verify that your solution is correct.
An easier way is to note that if ##V = S + (d/r)## then ##dV/dt = dS/dt = r V##, so ##V(t) = V_0 e^{rt}##, where ##V_0 = S_0 + d/r##.
