How do you solve for dp/dt=kP(1-P/M)
  • Thread starter Thread starter brandy
6 replies · 13K views · last reply
brandy
dy/dx=ky(1-y/M)
where p is smaller than m and k is positive
∫dy/(ky(1-y/M))=x
∫dy/(ky(1-y/M))=∫(a/ky + b/(1-y/M))dy
then i introduced 2 new variables (a and b)
multiplied them out so that
1/(ky(1-y/M))=(a(1-y/M)+bky)/(ky(1-y/M))
cancelled out the lower half and you have
1=a(1-y/M)+bky
then i get a little stuck, I am not even sure you can say that with the A and B because when you have 1/(x+2)^2 it equals a/(x+2)+b/(x+2)^2.
so yes. help?
brandy said:
dy/dx=ky(1-y/M)
dy/(ky(1-y/M))=x
That should be "dx" on the right side, not just "x".
dy/(ky(1-y/M))=a/ky + b/(1-y/m)
1=a(1-y/m)+bky
This is written confusingly- like the "x" magically turned into a/ky+ b/(1- y/m). Are "M" and "m" the same? Actually, this new equation does not derive from the previous one- you might want to write it separately or better, explain exactly what you are doing. You are writing the fraction on the left side in "partial fractions". 1/(ky(1- y/M))= a/ky+ b(1- y/M). Now multiply both sides of the equation by y(1- y/M): 1= a(1- y/M)+ bky.
Set y equal to things that make the original denominator 0: if y= 0, that becomes 1= a(1- 0)+ bk(0)= a. a=1. If y= M, 1= a(0)+ bkM so b= 1/M.
1/(ky(1-y/M))= 1/ky+ 1/M(1- y/M)= 1/ky+ 1/(M-y)
Now go back to your original equation: dy/ky+ dy/(M-y)= dx
Integate both sides.
then i get a little stuck, I am not even sure you can say that.
so yes. help?[/QUOTE]
[tex]\frac{dP}{dt} = kP(1-\frac{P}{M})[/tex] is a separable differential equation, so you can separate it into [tex]\int \frac{dP}{P(M-P)} = \int \frac{k}{M}\,dt[/tex]
Quite right, zcd. Then I believe the RHS is easy to evaluate, and the LHS needs a method of integration. Partial fraction decomposition, perhaps?
sorry. i just realized how many mistakes i made in typing that.
but I am pretty sure i fixed them all now, so for clarification just read over the first post.
Well, it's still separable, and I still think partial fractions would work.
Anybody else?
Separating the variables early on will make it easier to solve. It seems you have the general idea here by attempting partial fraction decomposition
∫dy/(ky(1-y/M))=x
but you didn't quite follow through. You will get the equations [tex]\int\frac{1}{ky}+\frac{1}{k(y-M)}\,dy=x[/tex]
