How Do You Solve for Time in Projectile Motion Equations?
  • Thread starter Thread starter Zashmar
    Quadratic
The discussion revolves around solving for time in projectile motion equations, specifically focusing on the equation 15 = 35 sin(Θ)t - 4.9t². Participants are exploring the implications of the variable Θ and how it affects the solution.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants are attempting to identify the correct coefficients for a quadratic equation derived from the projectile motion formula. Questions about the use of parentheses and the interpretation of variables are raised, alongside discussions on the quadratic formula and its application in this context.
The discussion is active, with participants providing guidance on identifying coefficients and rearranging the equation. There is an ongoing examination of the algebraic setup, and some participants are questioning the correctness of the expressions used in the calculations.
There are indications of confusion regarding the use of trigonometric functions and the correct application of the quadratic formula. Some participants express uncertainty about the arrangement of terms and the implications of including cos(Θ) in their equations.
Zashmar
15=35 sin Theta*t -4.9t^2
I have tried solving for t, I do not know how to...
please help
thank you
What is Θ? (If you click on the "Go Advanced" button you will be able to put in the Greek letters as needed it also allows you to use superscripts.
You did not use parenthesis so I can tell you mean
15=35 sin (Θ)*t -4.9t2, or
15=35 sin (Θ*t) -4.9t2, or
15=35 sin (Θ*t -4.9)t2, or
15=35 sin (Θ*t -4.9t)2, or
15=35 sin (Θ*t -4.9t2), or
The answer to your question depends on that. Bottom line: You need to learn to use parenthesis as needed.
15=35 sin (Θ)*t -4.9t^2
Sorry,
What is the solution to the equation at2 + bt + c = 0 ?
((-b(+-)sqrt(b^2 -4ac))/2a
I know the quadratic formula, but how will I do it if j have theta as well?
b = 35 * Sin(Θ) in this case. It is a symbolic formula, if it is a quadratic, it is valid.
Just make your equation "fit" the format of the formula and you will see what is a, what is b and what is c.
Then solve it.
So...
x= [itex](4.9 \pm \sqrt{24.01+2100 sin\vartheta}/(70 sin \vartheta)[/itex]
Zashmar said:
So...
It doesn't look like you applied the formula correctly. What did you use for a, b, and c?
Chet
a=35 sinΘ
b=-4.9
c=-15
This is wrong. You posted the correct formula above but identified wrong values for a, b and c.
Also, you missed a parenthesis.
a is the coefficient of the t^2 term, b is the coefficient of the t term and c is the independent term. Try again. Why don't you rearrange it as I suggested, it is a good practice if a, b and c don't seem ridiculously obvious.
Okay
So I have it now, how would i simplify the following (I have subbed it into x=35cos[itex]\vartheta*t[/itex])?
x=35cos[itex]\vartheta[/itex]([itex]-35 sin\vartheta \pm \sqrt{(35sin \vartheta)^2 -294}/-9.8[/itex]
I tried to put in the parentheses but it would not let me
You need to get the algebra right before we can help you simplify anything.
Chet
all terms except 35cos theta, should be divided by -9.8. I tired to show the parentheses but it wouldn't work
I may be missing something, but why is there a cos(theta) anyways?
Im subbing it into another equation
Be clearer, are you trying to do:
1)[itex]cos{(\theta \cdot t)}[/itex]
or
2)[itex]cos{(\theta)} \cdot t[/itex]
Also, it seems to me that your solution for x is still not correct. Check your signs.
The second option :)
As he said, redo it. From what I can see, your signs are wrong.
It seems you're solving a problem of projectile motion. Is this correct? Would you post the problem so we can help you more effectively?
