How Do You Solve Quadratic Equations in Non-10 Base Systems?
  • Thread starter Thread starter zaper
    Base Quadratic
6 replies · 3K views
zaper
I need to solve 0 = 5x2 - 50x + 125 with solutions x = 5, x = 8.
Referencing this thread I arrived at the equation (x - 5)(x - 8) = 5x2 - 50x + 125. Expanding
x2 - 13x + 40 = 5x2 - 50x + 125
I tried to simply compare coefficients here but I saw that for x2 this would give me 1b = 510 which I don't think is possible. So what I did instead was factor out a 5 giving
x2 - 13x + 40 = 5(x2 - 10x + 25) which I set up the system
1b = 110 -> 1 = 1
-13b = -1010 -> 1 * b + 3 = 10
40b = 2510 -> 4 * b + 0 = 25
The first equation is not helpful at all, the second givers b = 7 which is not possible with x = 8 and the third gives b = 6.25 which is also not possible.
I'm really stumped here. Any help would be awesome.
zaper said:
So what I did instead was factor out a 5 giving x2 - 13x + 40.
You factored out the 5 in base 10, at this point the best you can do by factoring out the 5 is x2 - (50/5)x + (125/5). Also since x = 8 is a solution, then the base must be greater than 8. Also what is (50/5) in any base (any base greater than 5)?
Wow, can't believe I got those sides mixed around like that...
Ok, so then if I can't factor out 5, how would you recommend I go forward? I'm getting stuck at the 110 = 5b
You can re-write the original equation as:
0 = 5 x2 + (5 b + 0) x + 1 b2 + 2 b + 5.
Where b is the base. You can factor out the 5 from this equation by dividing both sides by 5, but the last term will have fractions.
I don't understand what you mean by this. 1 in any base = 1 in any other base.
Just to be clear (since you haven't specified this in your post), is this the quadratic equation in base 10 or your unknown base "b"? Likewise, are the solutions x = 5 & x = 8 in base 10 or base "b"?
Assuming that these are all in base "b", then you should have
[tex]\alpha_{(b)}(x_{(b)}-5_{(b)})(x_{(b)} - 8_{(b)}) = 5_{(b)}x_{(b)}^2 - 50_{(b)} x_{(b)} +125_{(b)}[/tex]
That is, you should not be comparing a base "b" equation to a base 10 equation.
Ok, I just subbed in x = 5 and x = 8 and set them equal to each other. I got b = 13 which seems right to me
That's the correct answer. Hope we were able to help.
