How Do You Solve Quadratic Equations in Non-10 Base Systems?
  • Thread starter Thread starter zaper
    Base Quadratic
The discussion revolves around solving the quadratic equation 0 = 5x² - 50x + 125 in non-decimal (base "b") systems, with specific solutions proposed as x = 5 and x = 8. Participants explore various methods of solving the equation, including factoring and coefficient comparison, while addressing the implications of different bases on the solutions.
  • Homework-related
  • One participant attempts to solve the equation by comparing coefficients but encounters issues with the base representation, leading to confusion about the validity of certain equations.
  • Another participant suggests that factoring out the 5 should be done in the context of the base system, questioning the appropriateness of base 10 operations.
  • There is a discussion about the implications of the base being greater than 8 due to the proposed solution x = 8.
  • One participant rewrites the original equation in terms of base "b" and discusses the potential for fractions when dividing by 5.
  • A later reply emphasizes the need to clarify whether the equation and solutions are in base 10 or base "b," suggesting that comparisons should only be made within the same base system.
  • Another participant claims to have found a base of 13 by substituting the proposed solutions into the equation, though this claim is met with mixed responses regarding its correctness.
Participants do not reach a consensus on the correct approach to solving the equation or the validity of the proposed base. Multiple competing views remain regarding the interpretation of the equation in different bases and the correctness of the derived base value.
There are unresolved assumptions about the base system being used and the implications of operations performed in different bases. The discussion reflects uncertainty about the correct methodology for solving the equation in a non-decimal context.
This discussion may be useful for students and enthusiasts interested in quadratic equations, base systems, and mathematical reasoning in non-decimal contexts.
zaper
I need to solve 0 = 5x2 - 50x + 125 with solutions x = 5, x = 8.
Referencing this thread I arrived at the equation (x - 5)(x - 8) = 5x2 - 50x + 125. Expanding
x2 - 13x + 40 = 5x2 - 50x + 125
I tried to simply compare coefficients here but I saw that for x2 this would give me 1b = 510 which I don't think is possible. So what I did instead was factor out a 5 giving
x2 - 13x + 40 = 5(x2 - 10x + 25) which I set up the system
1b = 110 -> 1 = 1
-13b = -1010 -> 1 * b + 3 = 10
40b = 2510 -> 4 * b + 0 = 25
The first equation is not helpful at all, the second givers b = 7 which is not possible with x = 8 and the third gives b = 6.25 which is also not possible.
I'm really stumped here. Any help would be awesome.
zaper said:
So what I did instead was factor out a 5 giving x2 - 13x + 40.
You factored out the 5 in base 10, at this point the best you can do by factoring out the 5 is x2 - (50/5)x + (125/5). Also since x = 8 is a solution, then the base must be greater than 8. Also what is (50/5) in any base (any base greater than 5)?
Wow, can't believe I got those sides mixed around like that...
Ok, so then if I can't factor out 5, how would you recommend I go forward? I'm getting stuck at the 110 = 5b
You can re-write the original equation as:
0 = 5 x2 + (5 b + 0) x + 1 b2 + 2 b + 5.
Where b is the base. You can factor out the 5 from this equation by dividing both sides by 5, but the last term will have fractions.
I don't understand what you mean by this. 1 in any base = 1 in any other base.
Just to be clear (since you haven't specified this in your post), is this the quadratic equation in base 10 or your unknown base "b"? Likewise, are the solutions x = 5 & x = 8 in base 10 or base "b"?
Assuming that these are all in base "b", then you should have
[tex]\alpha_{(b)}(x_{(b)}-5_{(b)})(x_{(b)} - 8_{(b)}) = 5_{(b)}x_{(b)}^2 - 50_{(b)} x_{(b)} +125_{(b)}[/tex]
That is, you should not be comparing a base "b" equation to a base 10 equation.
Ok, I just subbed in x = 5 and x = 8 and set them equal to each other. I got b = 13 which seems right to me
That's the correct answer. Hope we were able to help.
26K
