How do you solve the total # of combination for 3 variable for 2 equations
  • Level: High School
  • Thread starter Thread starter ultimatebusta
    Combination Variable
7 replies · 3K views
ultimatebusta
I've been doing some math contest stuff, and I find a lot of questions that's like 3 different variables, with 2 equations. It asks me to find the number of different possible combinations.
Here's an example:
a+b+c = 110
a+2b+5c = 200
How many different combo of abc are there? (a, b, c are integers. and positive in this question, but not necessarily all questions.)
How do I solve these questions in general?
Mathematics news on Phys.org
In general for systems like this, there are an infinite number of solutions. Geometrically, this system of equations represents two planes in three-dimensional space. In this problem, the planes aren't parallel, so the planes intersect in a line. Each point in this line represents a solution to the system.
If a, b, and c are limited to integer values, the solutions will be at lattice points (points all of whose coordinates are integers).
If you have only one extra variable, then you can express all the variables as a function of a single variable, and it will be easy to see the conditions on this variable that make all the other variables positive.
You can, for example, subtract the first from the second, yielding:
b+4c=90 (3)
Now, subtract (3) from 1, yielding:
a-3c=20 (4)
From (4), we get by rearrangement:
c=(a-20)/3 (5)
Inserting (5) in (3), simplifying and rearranging:
b=-(4/3)a+350/3 (6)
Thus, the combinations (a,b,c) that fulfills the original equation can be written as
(a, (6), (5)), with "a" allowed to have any value.
Well I solved it via
since that 90 - 4c = b. 4c has to be less or equal to 90, which will make c less than 22. Include 0, so there's 23 solutions.
I'm not sure if this would be a way to solve all these types?
All of those with only one extra variable.
If you have n extra variables, you have to determine the number of integer points in an n-dimensional simplex
For example, if you only have a + 2b + 3c = 11 and a>0, b>0 and c>0.
you can write this as a = 11 -2b - 3c, and from this you can see that
2b + 3c < 11, so you need to count the number of integer points in the
triangle b>0, c>0, 2b+3c<11, this will get very hard for higher dimensions,
because the simplex will have so many potential corners.
Yeah I agree. Here's another one of these type of contest question.
a^2 - 4b > 0
a + b = ?
seems very difficult.
Also from all the practise questions I've seen, that the most they'll give you is 4 var with 3 eq. Usually it's 3var with 2 eq.
a^2 - 4b > 0
a + b = ?
Let's switch variables (letting x = a and y = b) and graph the inequality.
With this change, the inequality becomes x2 - 4y > 0, or y < (1/4)x2. There are an infinite number of solutions to this inequality -- all of the points below the graph of the parabola y = (1/4)x2.
The best you can do for x + y is to write another inequality. You can't say that x + y equals any specific number.
