How do you solve this nonlinear first order DE
  • Context: Undergrad
  • Thread starter Thread starter kingkongsr.
    First order Nonlinear
The discussion revolves around solving a nonlinear first order differential equation of the form dy/dx = mx + b - k*y^2, where m, b, and k are constants. Participants explore various methods for solving this equation, including the Riccati equation approach and transformations involving Airy functions.
  • One participant expresses difficulty in solving the nonlinear differential equation and seeks assistance, mentioning a recommendation for the Riccati method.
  • Another participant suggests differentiating both sides of the equation twice to obtain a new equation dependent only on y, drawing an analogy to homogeneous equations.
  • A participant requests a step-by-step solution process for the equation.
  • One participant provides a complex solution involving Airy functions, indicating a method that may be beyond the understanding of some others in the discussion.
  • Another participant questions the feasibility of integrating both sides of the equation after multiplying by dx, suggesting that separation of variables may not be applicable due to the presence of the y^2 term.
  • A later reply discusses the transformation of the equation into a Riccati form and presents a solution involving Airy functions, while also noting the complexity of the solution derived from computational tools.
  • Some participants express confusion regarding the Airy functions and the methods used to arrive at the solutions, indicating a lack of familiarity with these concepts.
Participants do not reach a consensus on the best method to solve the equation, with multiple competing views and approaches presented throughout the discussion. Some participants express confusion and seek clarification, while others provide technical solutions that may not be universally understood.
There are limitations in understanding the transformations and the use of Airy functions, as well as unresolved mathematical steps regarding the integration and separation of variables. The discussion reflects a range of familiarity with nonlinear differential equations among participants.
kingkongsr.
I am having trouble solving the following nonlinear first order differential equation:
The variables m, b and k are constants.
I have had DE in school, but it was mostly linear first order, so I am not sure how to solve this one. Someone has recommended Riccati but I do not know how to go about solving it.
Please help.
Aside from describing functions I haven’t studied nonlinear differential equations. It would seem to me though if you differentiate both sides of the equation twice you would get an equation that only depends on y. Perhaps this could be thought as somewhat analogous to the homogenous equation.
How would you go about solving the equation? I need a step by step.
\left\{\left\{y(x)\to \frac{\frac{k m \text{Bi}&#039;\left(\frac{b k+m x k}{(k m)^{2/3}}\right)}{(k m)^{2/3}}+\frac{k<br /> m \text{Ai}&#039;\left(\frac{b k+m x k}{(k m)^{2/3}}\right) c_1}{(k m)^{2/3}}}{k \left(\text{Bi}\left(\frac{b k+m<br /> x k}{(k m)^{2/3}}\right)+\text{Ai}\left(\frac{b k+m x k}{(k m)^{2/3}}\right) c_1\right)}\right\}\right\}
where Ai is the airy function Ai[x], Bi is again some variant of the airy function Bi[x], and the primes are their respective derivatives
Well that's beyond my understanding.
I was hoping for something easy.
what do you mean beyond your understand? it's just a function, put a number in get a number out
What's an airy function?
Show me the process by which you solved it, starting with the original equation. Then explain to me what the airy function is.
the process by which i solved it is simple: i plugged it into mathematica. and i have no idea what the airy function is but I'm sure wikipedia does.
I just looked at the equation again, it is suppose to be: dy/dx = m*x + b - k*y^2 where m is multiplied by x. However, can both sides be multiplied by dx such that dy = (m*x + b - k*y^2) dx where the right hand side can be integrated with respect to x. Then both sides are divided by the integral of the right side such that dy/[IntegralWithRespectx(m*x + b - k*y^2)] = 1. Then the left hand side can be integrated with respect to y such that, IntegralWithRespecty[1/[IntegralWithRespectx(m*x + b - k*y^2)]] =1. I have never heard of that, but can that be done?
u don't know y, how can u perform that int?
matco
I just need someone to explain to me what the answer to the equation is. Can someone do that without plugging it into a computer program.
No, what you're trying to do there is a separation of variables, but you can't separate the y^2 term on the right hand side from the x terms, so you still have to integrate over y^2 with respect to x - effectively what you've done is converted a differential equation into an "integral equation".
It's weird that taking another derivative, as suggested above, doesn't seem to be be useful. Taking the derivative, you get:
\frac{d^2y}{dx^2} + 2ky = m
This is a linear second order homogeneous equation which can be solved in closed form, but the first derivative of the solution that equation can't be matched to mx + b. Huh... I haven't seen that before...
If you do want to try and solve it via the suggested "Riccati Equation", of which this is apparently a form of, with q_1(x) = 0, try looking at the wikipedia article: http://en.wikipedia.org/wiki/Riccati_equation. Of course, if computers are giving Airy functions as solutions, then you're probably going to have to resort to a power series solution once you boil that down to the linear 2nd order equation as described in the article (or perhaps you can identify the resulting second order ODE with Airy's equation: u&#039;&#039; + xu = 0 - but probably not. I don't know; that computer solution is ugly.)
You can rewrite this equation into:
\frac{dy}{dx}+ky^2=mx+b
Which is a Riccati equation, using the following transformation:
y(x)=\frac{1}{ku}\frac{du}{dx}
One obtains:
\frac{d^2u}{dx^2}-k(mx+b)u=0
Substituting now:
k(mx+b)=(km)^{2/3}t
The equation becomes:
\frac{d^2u}{dt^2}-tu=0
Which is the differential equation of Airy, with solution:
u(t)=c_1 A_i(t)+c_2 B_i(t)
In which now Ai and Bi the two independent solutions of the equation, called the functions of Airy. Upon using the inverse transformations, one gets:
u(x)=c_1 A_i\left[\frac{k(mx+b)}{(km)^{2/3}}\right]+ c_2 B_i\left[\frac{k(mx+b)}{(km)^{2/3}}\right]
The derivative is:
\frac{du}{dx}=c_1 \frac{km}{(km)^{2/3}} A_i^{&#039;}\left[\frac{k(mx+b)}{(km)^{2/3}}\right]+ c_2 \frac{km}{(km)^{2/3}} B_i^{&#039;}\left[\frac{k(mx+b)}{(km)^{2/3}}\right]
Thus the solution to the original equation becomes (after rewriting a bit):
y(x)=\frac{(km)^{2/3}}{k} \frac{A_i^{&#039;}\left[\frac{\displaystyle k(mx+b)}{\displaystyle (km)^{2/3}}\right]+ C B_i^{&#039;}\left[\frac{\displaystyle k(mx+b)}{\displaystyle (km)^{2/3}}\right]} {A_i\left[\frac{\displaystyle k(mx+b)}{\displaystyle (km)^{2/3}}\right]+ C B_i\left[\frac{\displaystyle k(mx+b)}{\displaystyle (km)^{2/3}}\right]}
Hope there are no typo's in here.
