How Does a Capacitor Discharge Over Time?
5 replies · 4K views
Tobus
Hi,
I am studying an engineering program in university. I have a piece of lab coursework to do and I am struggling to find information on it.
The lab report was based on 'The discharge of a capacitor with time using an oscilloscope'
It sounds silly but what is the theory of a capacitor discharging? I also need to find the principle of why is discharges relevant to the experiment at hand.
I know I'm asking a lot but I think I'm in the right place to ask :)
A huge thanks to anyone that can help me :)
Hi Tobus! :smile:
From capacitor in the PF Library
Inverse exponential rate of charging:
A capacitor does not charge or discharge instantly.
When a steady voltage [itex]V_1[/itex] is first applied, through a circuit of resistance [itex]R[/itex], to a capacitor across which there is already a voltage [itex]V_0[/itex], both the charging current [itex]I[/itex] in the circuit and the voltage difference [itex]V_1\,-\,V[/itex] change exponentially, with a parameter [itex]-1/CR[/itex]:
[tex]I(t) = \frac{V_1\,-\,V_0}{R}\,e^{-\frac{1}{CR}\,t}[/tex]
[tex]V_1\ -\ V(t) = (V_1\,-\,V_0)\,e^{-\frac{1}{CR}\,t}[/tex]
So the current becomes effectively zero, and the voltage across the capacitor becomes effectively [itex]V_1[/itex], after a time proportional to [itex]CR[/itex].
Hey thanks :)
Thank you for the help,
For my introduction I have written this,
"We are doing this experiment to understand if the capacitor discharges at a particular rate to show that the theory of a capacitor discharges at an exponential rate when a direct current is removed. Capacitors are used in many circuits and electronic storage devices. As the capacitor is charged from the direct current supplied there is a force of attraction between the two plates as one becomes positively charged and the other becomes negatively charged. Once the charge/voltage? has been removed the capacitor starts to discharge and the flow of electrons moves across the plates. The rate of discharge decays exponentially to time."
What do you think, do I get my point across properly? More importantly is the physics correct! lol
Hi Tobus!
hmm …
i] the electrons do not move across the plates … they go the long way round!
ii] you haven't actually explained anything … why do the electrons go the long way round (especially when, as you point out, there's an attractive force the short way round) … and why is it exponential, or at least, what is the governing equation? :smile:
What do you mean by long way around :S. Sorry I'm not so sure lol.
I know its exponential decay as the current decreases at the same ratio in successive equal intervals of time.
How about that? Do you think I should put it in somewhere.
For my introduction I simply need to explain the theory of what a capacitor does. :)
Again from PF Library:
Displacement current:
No current ever flows through a functioning capacitor.
But while a capacitor is charging or discharging (that is, neither at zero nor maximum charge), current is flowing round the circuit joining the plates externally …​
but why? (how does it know? :biggrin:)
