How does a discharge UV lamp works
The discussion focuses on the operational principles of discharge UV lamps, specifically how rare gases like Helium are excited to emit UV photons. Electrons are accelerated by an electric field, leading to inelastic collisions with gas atoms, which become excited and subsequently emit UV light. The emitted UV photons interact with the lamp's coating, producing visible light. The conversation also distinguishes between hot cathode and cold cathode lamps, highlighting the different methods of electron generation and the importance of breakdown voltage in gas ionization.
  • Understanding of gas discharge principles
  • Knowledge of thermionic emission and cold cathode technology
  • Familiarity with the concept of breakdown voltage in gases
  • Basic principles of electron acceleration in electric fields
  • Research the differences between hot cathode and cold cathode discharge lamps
  • Learn about the breakdown voltage and its effects on gas ionization
  • Explore the mechanisms of inelastic collisions in gas discharge processes
  • Investigate the materials used for coatings in UV lamps and their interaction with emitted photons
Engineers, physicists, and anyone involved in the design or application of gas discharge lamps, particularly those interested in UV light generation and its practical uses.
poul
I think i have looked at like 20-30 web pages, and i can't find a simple step-by-step explanation of the operational principle.
I know, that when a rare gas like Helium, relaxes from an excited state two characteristic emission lines occur. But how do you excite the gas in the first place?
I know you can excite it, by shooting some electrons through the gas, but we have no free electron in the system, since the electric field should not be strong enough to ionize the helium atom by itself.
There are free electrons in the system. The electrons get accelerated by the electric field. Once the electrons are a high enough kinetic energy, the atoms absorb a discrete quantity from them in an inelastic collision, becoming excited. The unstable, excited atoms quickly fall back to a lower state, emitting a UV photon in the process. This UV photon interacts with the coating of the tube in a similar manner, transferring energy to excited/ground states, emitting visible light.
I read your post again, and I am not sure what you mean. You have no free electrons in a system you are doing? I am not sure how that would work in this case. All gas discharge lamps I know of have free electrons flowing through an ionized gas.
The (electrons in the) atoms can also be excited through inter-atom collsions.
okay so for a normal gas discharge lamp, we have free electrons you say. Are these made, by heating a filament or similar and then accelerated?
It depends on if it is a hot cathode or a cold cathode. Hot cathode lamps use thermionic emission to release the electrons from the electrodes to maintain conduction in the gas. Cold cathodes need an initial (much higher than hot cathode) voltage to ionize the gas and make it conductive.
Atmospheric gas is typically non-conductive until this "breakdown voltage" is applied. The voltage necessary is reduced in a vacuum and with certain gases, which is why these lamps have the gases they do.
