Karol
- Messages
- 1,380
- Reaction score
- 22
A squirrel of mass m runs with a constant velocity v0 relative to the ring of radius R with moment of inertia I. the friction of the ring is proportional to it's angular velocity and is ##M_f=-k\dot{\phi}##.
What is the equation of motion relative to the laboratory frame
From the condition that the squirrel's velocity v0 relative to the ring is constant, find a relation between ##\dot{\phi}## and ##\dot{\theta}##
Get a single differential equation for θ in order to find the squirrel's motion relative to the ground
Assume there's no friction and that θ(t)<<1 then solve for θ(t)
For the ring: ##M=I\cdot \ddot{\phi}##
Solution for 2nd order homogeneous differential equation: ##\theta(t)=e^{rt}##
The restoring force is ##mg\cdot \sin\theta## so:
$$mg\cdot \sin\theta-k\dot{\phi}=I\cdot \ddot{\phi}$$
The relation between ##\dot{\phi}## and ##\dot{\theta}##: ##\left(\dot{\phi}+\dot{\theta}\right)R=v_0##
$$\rightarrow \dot{\phi}=\frac{v_0}{R}-\dot{\theta},\ \ddot{\phi}=-\ddot{\theta}$$
I combine these two to get a single differential equation:
$$mg\cdot \sin\theta-k\left(\frac{v_0}{R}-\dot{\theta}\right)=-I\ddot{\phi}$$
$$\rightarrow I\ddot{\theta}+k\dot{\theta}+mg\cdot\sin\theta=\frac{kv_0}{R}$$
With the simplifying assumptions: ##\ddot{\theta}+\frac{k}{I}\dot{\theta}=0##
The solution to this differential equation is ##\theta=e^{rt}##
$$\rightarrow r^2e^{rt}+\frac{k}{I}r\cdot e^{rt}=e^{rt}\left(r^2+r\frac{k}{I}\right)=0$$
$$\rightarrow r=-\frac{k}{I},\ \theta(t)=C\cdot e^{-\frac{k}{I}t}$$
At t=0 θ=0 →C=0 and it can't be
