How Does a Variable Coefficient of Kinetic Friction Affect Block Acceleration?
10 replies · 14K views · last reply
bestchemist
A block of mass m is at rest at the origin at t=0. It is pushed with constant force F0 from x=0 to x=L across a horizontal surface whose coefficient of kinetic friction is μk=μ0(1−x/L). That is, the coefficient of friction decreases from μ0 at x=0 to zero at x=L.
ax = (dvx/dx)vx
a = (F0 - mg(1-x/L))/m
√(2L(F0m−μ0g))+√μ0gL
and it wrong
voko said:
What is the problem?
find an expression for the block's velocity when it reaches position x=L.
Express your answer in terms of the variables L, F0, m, μ0, and appropriate constants.
Please show your work. It looks like you made some math errors, and you also left out a factor of μ0 in your equation for the acceleration.
vdx = (Fo/m)dx - uogdx + (uog/L)xdx
(1/2)v^2 = (Fo/m)x - uogx + (uog/2L)x^2
and solve for v and plug x = L
I got
Right so far
I got
That's certainly wrong. For others to see where you went wrong you will need to post every step of your working.
haruspex said:
Right so far
v^2 = 2 (Fo/m)x - 2 uogx+ 2(uog/2L)x^2
v^2 = 2x ((Fo/m)- uog) + (uog/L)x^2
v^2 = 2L((Fo/m)- uog) + (uogL)
v= √(2L((Fo/m)- uog) + (uogL))
is it right?
is it right?
Yes, but you can simplify it a little.
Where can I simplify it? I thought I already simplified it to the most simplest form.
Can you give some hint?
Chestermiller said:
Check out the terms under the radical (which extends over the entire rhs), and see if you can combine anything.
okay.. got it
