How Does Air Pressure Affect Electron Beam Penetration?
The discussion revolves around the relationship between air pressure and the penetration distance of an electron beam in a gaseous medium. Participants explore theoretical and experimental aspects of how electron collisions with air molecules affect the maximum distance traveled by the beam, considering factors like pressure, temperature, and scattering cross-sections.
  • Experimental/applied
  • One participant seeks to relate the maximum distance traveled by an electron beam to air pressure, questioning if a specific formula exists.
  • Another participant suggests looking into diffusion formulas but questions the focus on a single particle versus a beam of electrons.
  • A participant emphasizes the importance of considering the resistance of air, noting its correlation with temperature and pressure.
  • Discussion includes the concept of penetration length being linked to the distance at which current dissipates to zero due to air resistance.
  • One participant highlights the need for the collision cross-section of electrons with air molecules, stating that pressure affects molecular density and thus scattering probabilities.
  • A participant mentions an experimental setup involving a hot filament and a vacuum pump, aiming to derive a formula for penetration distance based on pressure.
  • Another participant provides a formula for number density and discusses the mean free path of electrons in relation to scattering events in the gas.
Participants express various viewpoints on how to approach the problem, with no consensus on a single method or formula to relate air pressure to electron beam penetration distance. Multiple competing models and ideas are presented, reflecting differing interpretations of the underlying physics.
Participants note the dependence of their arguments on assumptions about temperature, the specific configuration of the experimental setup, and the nature of scattering processes involved. There are unresolved aspects regarding the exact conditions under which the electron beam operates.
Ash Khan
Hey! I am trying to figure out this one problem. Some help would be appreciated.
How can i relate the maximum distance traveled by an electron at a given pressure?
So electron is colliding with air molecules. I wonder if there is a formula or derivation which relate maximum penetration and pressure of air?
You are looking for a diffusion formula. Why are you only interested in the penetration of 1 particle and not many or even atoms?
I am actually interested in a beam of electron
Sorry just the way you phrased your question led me to wonder.
Okay, because you are asking about a beam of electrons , I change my advice to that of looking up the resistance of air. The pressure is correlated with temperature and how fast the particles are moving. Although because you are only considering a beam of electrons and not regular atoms, the scattering is not what is considered a diffusion type scattering. Resistance depends on pressure though ( through the correlation with temperature. Find out the resistivity of air.
The penetration length is calculated from the distance at which the current dissipates to zero from the resistance of the air.
I think you need the cross-section for collisions of electrons at your beam energy with the molecules in air.
Pressure will determine the density of molecules, and cross-section times density gives the scattering probability per length, which then leads to the fraction of unscattered electrons as function of distance.
Edit: at atmospheric density, radiation length in air at atmospheric pressure is about 300 meters if I remember correctly. This can be used for high-energetic electrons.
What is the context of your question? Why will you have a beam of accelerated electrons in a vessel that has some air in it?
It seem like how far the beam makes it into the air portion of the vessel will also depend on the anode configuration. Is the beam aimed at an anode surface?
This makes sense but i am just confused how i should correlate pressure directly with the maximum penetration distance of electron beam. I tried using deceleration, momentums and other techniques
So, i am doing this experiment where i have a hot filament which is shooting a beam of electrons. Beam is accelerated by two plates with a constant potential. I have a vacuum pump to pump out air and decrease the pressure in the container (cylindrical chamber). I want to derive a formula where i can just enter the value of pressure and figure out how much distance the beam will travel before it stops.
You can use the formula for the number density [itex]n= \frac{P_{vac}}{k_B T}[/itex]
Where [itex]P_{vac}[/itex] the pressure and [itex]T[/itex] is the temperature. Since you don't know what kind of temperatures you have in your device, using the room temperature is the only natural choice.
So the number of scatterings of the electrons over the gas is [itex]N_{scat} = \sigma_{e/gas} \frac{P}{k_BT} L[/itex] in a total path [itex]L[/itex].
Now the quantity that multiplies the distance L is giving you the inverse mean free path of your electrons within the gas: [itex]\lambda_{mfp} = \frac{1}{\sigma n} = \frac{k_B T}{\sigma_{e/gas} P}[/itex]. After 1 [itex]1 \lambda_{mfp}[/itex] your electron beam intensity has dropped by [itex]e^{-1}[/itex].
  • · Replies 45 ·
  • · Replies 20 ·
  • · Replies 55 ·
21K
