How Does Air Resistance Affect Spring Compression?
The problem involves a mass-spring system where an object is dropped onto a spring, and the effects of air resistance and different gravitational conditions are considered. The subject area includes mechanics, specifically energy conservation and spring dynamics.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the application of physical principles related to energy and springs. Questions are raised about relevant equations and the initial approach to solving the problem.
The discussion is ongoing, with participants seeking to clarify the fundamental principles and equations that apply to the problem. Some guidance has been offered regarding starting points, but no consensus or solutions have been reached yet.
There is an indication that the original poster may not have made a serious attempt at the problem, which has led to some questioning of their engagement with the material. The problem also involves different scenarios, including the effect of air resistance and varying gravitational conditions.
lefthand
i need help with this problem. i have no idea how to do this.
A 1.41 kg object is held 1.38 m above a relaxed, massless vertical spring with a force constant of 288 N/m. The object is dropped onto the spring.
(a) How far does the object compress the spring?
1 m
(b) Repeat part (a), but now assume that a constant air-resistance force of 0.872 N acts on the object during its motion.
2 m
(c) How far does the object compress the spring if the same experiment is performed on the moon, where g = 1.63 m/s2 and air resistance is neglected?
3 m
It's pretty obvious you just put down random answers and haven't made a serious attempt at solving the problem, which is why you're not getting any responses.
What physical principle do you think applies here? Why do you think it does? What are some of the relevant equations?
i didn't put those answer. i really don't know how to do this problem or where to start
What equations are there that have something to do with energy? What equations are there that have something to do with springs? Looking at these would be a good starting point.
If you don't actually know the equations, look in your textbook for them.
