The discussion revolves around the principles of lift generated by airplane wings, exploring various theories including Bernoulli's principle and Newton's laws. Participants engage in technical explanations, conceptual clarifications, and debates regarding the mechanics of lift, particularly in relation to different flight conditions such as flying upside down.
- Exploratory
- Technical explanation
- Conceptual clarification
- Debate/contested
- Some participants suggest that if Bernoulli's effect were the primary cause of lift, airplanes would not be able to fly upside down.
- Others argue that Bernoulli's equation does not prevent an airplane from flying upside down if there is a sufficient angle of attack, although it may result in increased drag.
- One participant requests literature on fluid dynamics related to lift, indicating a desire for deeper understanding.
- There is a discussion about the need for adjustments in calculating pressure gradients over a wing due to the effects of flow acceleration perpendicular to the wing surface.
- Some participants assert that the potential flow equations already account for the necessary accelerations when calculating velocity distributions around a wing.
- Concerns are raised about the application of Bernoulli's equation across the wing's surface, with some suggesting that work is performed on the air as it interacts with the wing.
- One participant emphasizes that there must be a change in speed of the air over the wing, even at flat pitch, challenging the notion that no work is done by the wing on the air.
Participants exhibit disagreement regarding the role of Bernoulli's principle in lift generation, particularly in the context of flying upside down and the implications of work done on the air. The discussion remains unresolved with multiple competing views presented.
Some discussions reference the need for specific assumptions and conditions when applying Bernoulli's equation, as well as the complexities involved in modeling fluid dynamics around wings.
