How does an Op-Amp "find" equilibrium (w/ Negative Feedback)?
50 replies · 10K views · last reply
TimNJ
Hi everyone,
I've been seeking the answer to this question for a long time. I've looked at posts like...
https://www.physicsforums.com/threads/op-amp-transient-state.855512/
and
https://www.physicsforums.com/threa...edback-in-an-op-amp-work-conceptually.584881/
...but I am struggling with one concept. Say we apply a 1V step input, with an Aol of 1000, and a feedback factor of 0.5 (so ideal closed loop gain of 2), how does the op-amp "know" to stop rising at Vout = 1.996V?
The finite gain equation says Vout = Aol(V+ - V-), but in this case if V+ = 1V, and V- = 0.5(Vout), then Vout would have to be 1.996V in order for it to simultanteously be 2V. ? Since the input differential is dependent on the output, what is this equation even saying?
The op-amp does not "know" you want 2V on the output, per say...so what's stopping it from rising to 1.997V, and producing 1.5V on the output?
Here's how I've been thinking about it:
At first there's a large input voltage differential, (1V-0V), so the op-amp "tries" to reach a very high output voltage (1000V) but is physically limited by its slew rate. As the output rises as quickly as it can, it subsequently reduces the input voltage differential and thus it "tries" to reach lower and lower voltages. In this case, when the voltage reaches 1.99V, it is "trying" to reach 5V and at 1.996V, it is "trying" to reach 2V.
I'm just not sure how the op-amp says "this is a good place to stop!" when reacting to that step input.
Thanks a lot.
Tim
TimNJ said:
Hi everyone,
Tim - I have tried to explain the sequence step-by-step in the first reference you have given (post#4, point 6).
Please, read again and come back with a specific question (if necessary).
I think the situation is confused between three differing models. We have two ideal models and a "real world" model with posters assuming models without stating them explicitly.
Real circuits behave as they behave.
One of the ideal models is analog. In this model there are no iterations.
One of the models is digital in the time sense. Iterations exist.
IMO the digital a bad model because the circuit does oscillate. This is because (as you point out) it doesn't know when to stop. The first iteration drives it to one rail, then the second iteration drives it to the other. Rinse, repeat. But understand this is a problem with the model, not the circuit it represents.
All I can say is that some people like to think in discrete time units. That doesn't work well in this case. LvW tried (not unreasonably) to overcome this model weakness by dividing the time step and allowing the system to detect and respond to the zero crossing. That is a reasonable cludge to a bad model allowing it to work better.
Yes - I agree to the above.
It was only an attempt to describe the finding of an equilibrium by splitting the whole process into discrete time steps.
In reality, there is not such a "circulation of signals within the feedback loop".
For my opinion, it is sufficient to state (and to realize that/why this is true): In a negative feedback system there is only one stable operating point and the system automatically will find this equilibrium because: A further voltage increase (decrease) at the output will immediately cause a corresponding reduction (enhancement) of the differential input voltage - thereby correcting the disturbance at the output (operating point is shifted back to its stable position).
Amplifiers and feedback circuits have a "propagation delay" just like logic gates do but in analogue circuits it's usually called something like "phase delay" or "phase shift". It's quite possible for this to cause an OP Amp to overshoot the expected output voltage before returning to the "correct" value. Sometimes it can even cause the OP Amp to oscillate.
As I recall the fix is to use frequency compensation...
https://en.wikipedia.org/wiki/Frequency_compensation
and many OP Amps have built in frequency compensation to make them easier to use. This is a complex area that beginners might wish to avoid until they really have to understand it. I even understood it once upon a time.
More from Texas instruments here...
http://www.ti.com/lit/ml/sloa079/sloa079.pdf
Thank you everyone for your replies.
I've been scouring the internet from allboutcircuits, to stackexchange, to edaboard, to eevblog, and so forth...and I basically keep coming up with the same "answer" to my question. I think the real answer must be more complex than I thought.
LvW, I guess the thing I can't wrap my head around is that it seems like a chicken and the egg scenario to me. Most explanations who might try to explain it in the way you have say that the output reaches some (seemingly random) voltage which is just enough to maintain another (seemingly random) differential input voltage. And that small differential voltage keeps the output in the linear region. Sure, that makes sense, a very small differential voltage (nV, uV) amplified by a huge open loop gain will make linear amplification possible.
LvW said:
4.) At this very moment (assuming an open-loop gain Aol=1E4) , the opamp is in its linear amplification region because the diff. voltage is Vdiff=Vin-0.99980004=1-0.99980004=0.00019996V.
As a result, the output voltage is Vout=Vdiff*Aol=0.00019996*1E4=1.9996001V.
Mathematically, it all checks out...My issue is, what physical phenomenon is causing the op-amp to settle at that (seemingly random) voltage? There is no little man inside the op-amp that you say "Hey I'd like to amplify this signal with a gain of 2". So what's the reason it does actually get very close to the voltage you want?
Maybe I'm really overthinking this, or maybe it's more than my brain can understand..
Thanks for all your help, everyone.
A properly designed op-amp morphology has circuit elements that keep the two inputs at the same voltage level. That is the key.
When one input tries to move away from the other, the other one matches it.
The concept of "finding equilibrium" implies phase delay and complex loop operation. I'll choose to ignore that for a moment. Assume the amp is instantaneous and has no input current, the loop has no capacitance or inductance, and it just goes to equilibrium - INSTANTLY. Calculate equilibrium. The circuit just operates there. PERIOD!
Now, if you want to add some capacitance, inductance, phase delay, etc, then put them into your equations and calculate what happens over time.
The whole exercise of iterating in your mind is a crutch. It is not reality. I said this in another thread and was told I was wrong. But, I'm not.
Vout = ((V+) - (V-)) * 1000
V+ = 1
V- = Vout/2
Calculate Vout. That is the answer. The amp just operates at that point. No iterations.
If you have capacitance and inductance and delays, you need differential equations that describe the operation in time. If you want to
try to model that in your mind as causing iterations, you can, but it is not in any way accurate. Or, if you want to use iterations as a crutch to try to solve the above simple equation, you can do that also. But it is a crutch, not reality.
I think we need to ban speaking in terms of these mystical iterations and deal with the proper differential equations.
EDIT: to be clear, I realize precise iterations can be used to solve difference equations, but that is not the technique being referred to in any of the examples.
Try looking at it this way, using your example of inverting gain of 2.
1) Consider that an opamp has an input impedance across its input terminals. This is an internal characteristic of the opamp.
2) When a current flows thru this input impedance it of course generates a voltage. That is the differential input voltage which, when amplified by the open loop gain, appears at the output.
3) A signal input voltage is applied to a resistor connected to the inverting input. This causes a current to flow thru the input impedance, which generates a voltage.
3A) This voltage is amplified and eventually appears at the output. I say "eventually" because the output can't instantaneously change to a new value.
4) The feedback resistor, between the output and the inverting input, is twice the value of the resistor connecting the signal to the inverting input.
5) As the output voltage changes, the current thru the feedback resistor flows to the inverting input terminal. Since this is an inverting amplifier, this feedback current opposes the current coming thru the signal input resistor, and decreases the voltage at the input.
6) As the output continues to rise, more current flows thru the feedback resistor, reducing the voltage on the inverting input.
7) Eventually the feedback current equals the signal input current. Since the feedback resistor is twice the value of the signal input resistor, the output voltage will have to be twice the input voltage. At this point there is no longer a differential voltage at the input. (Actually there is a very small voltage. This small voltage is what is required, when multiplied by the open loop gain, to generate the output voltage)
8) With no (or very little) differential input the output stops changing.
9) This is the stable state. If the output drifts a little bit, the current thru the feedback resistor changes and changes the voltage on the inverting input.
this is incorrect
first rule of op-amps, No current flows into or out of the op-amp inputs
also incorrect because it's based on your previously stated error
this should have been more correctly stated as ...
the difference in voltage between the 2 inputs generates an internal error voltage that is amplified
and appears at the output. This error voltage works to keep the 2 inputs at the same voltage
the value is whatever you want it to be to set the gainDave
You are correct for an ideal opamp, or one with infinite gain operating in its linear region.
See pg5, table 6.6, input resistance
http://www.ti.com/lit/ds/symlink/lm741.pdf
I used that approach because it was simpler than equivalent resistance seen at the input terminal. In retrospect, I could have used a voltage divider equivalence.
TimNJ said:
Mathematically, it all checks out...My issue is, what physical phenomenon is causing the op-amp to settle at that (seemingly random) voltage? There is no little man inside the op-amp that you say "Hey I'd like to amplify this signal with a gain of 2". So what's the reason it does actually get very close to the voltage you want?.
Tim - no, it is not a "random voltage". It is the only voltage which is possible and which meets the constraints imposed by all the oither parameters (open-loop gain, feedback circuit, supply voltage, input voltage,...).
Perhaps it helps to think of the oppopsite: Positive feedback.
Example:
* Transistor without any negative DC feedback. Let`s assume there is a certain dc operating point defined by Ic and Vce.
Now - let`s further assume that the environmental temperature is rising. Because of physical laws the DC current Ic and also the product Ic*Vce will increase. Hence, the Ic increase causes additioinal heating of the transistor and - under certain conditions - we have a "thermal runaway" because the whole process supports its own increase. Finally, the transistor will be destroyed. That`s the result of positive (thermal) feedback.
* Exactly the opposite happens in case of negative feedback. Any unwanted disturbance at the output acts back to the input in such a way that this disturbance is reduced (ideally, back to the former value). Now - after power switch-on, any operating point other than the desired one (designed with external components) is such a deviation from the designed operating point. And this operating point designed by external parts is the only one which fulfills all the equations (Ohm, Kirchhoff, output=input*gain,...).
In our example, the (approximate) gain of "2" is simply determined by the feedback factor of 0.5 (as the calculation shows).
even in everyday use that rule is still important
the tiny current, that in reality, does flow in and out is called the input bias current measured in fA to uA ( maybe up to a couple of uA max --- commonly in the pA range) depending on the quality of the amp. Manufacturers work to make this as small as possible.
it is minimised as much as possible ( almost cancels it out) by the application of current sources within the op-amp to each input.
for most practical purposes it isn't a problem and can be ignored. Its only when using op-amps in high precision circuits that it needs to
be dealt with and that is done relatively easily to significantly lower its effectsDave
Which "rule" are you referring to?
read up and follow the thread :wink:
Is this really your answer?:frown:
davenn said:
this is incorrect
Current can flow through the input impedance without flowing into the op-amp. This depends on the topology.
You are correct in the case we're discussing though. But it's a distinction to keep in mind.
TimNJ said:
LvW, I guess the thing I can't wrap my head around is that it seems like a chicken and the egg scenario to me. Most explanations who might try to explain it in the way you have say that the output reaches some (seemingly random) voltage which is just enough to maintain another (seemingly random) differential input voltage. And that small differential voltage keeps the output in the linear region. Sure, that makes sense, a very small differential voltage (nV, uV) amplified by a huge open loop gain will make linear amplification possible. Mathematically, it all checks out...My issue is, what physical phenomenon is causing the op-amp to settle at that (seemingly random) voltage? There is no little man inside the op-amp that you say "Hey I'd like to amplify this signal with a gain of 2". So what's the reason it does actually get very close to the voltage you want?
It's because the opamp has a huge gain (much bigger than 2). Even the slightest difference between +ve and -ve inputs is magnified enormously.
Imagine you are trying to trace a line with a pencil...you would be able to follow the line more closely if you use a magnifying glass to check for errors. The magnifying glass would make any error look huge.
I too had a difficult time arriving at the point where this was intuitive.
Chicken-egg indeed.
Jeff hit the answer in post 7, just he didn't hit it hard enough to make the anvil ring .
Creative thought requires exaggeration so let me rant.
Forget iterations and approach to equilibrium , that's too much math.
The key is to grasp the difference between
an operational amplifier
and
an operational amplifier circuit.
From a thread yesterday
Let's make clear the difference between
"An Operational Amplifier"
and
"An Operational Amplifier Circuit"
An "operational amplifier" is an amplifier with high but finite gain perhaps 10^5 or 10^6 volts per volt.
It is represented by that ubiquitous triangle with 2 inputs and one output.
Its gain is given on its datasheet as Avol , acronym for Amplification, volts per volt, open loop.
An "operational amplifier circuit" is such an amplifier wrapped in a circuit that let's it force its inputs equal to one another by means of feedback.
It is the duty of the circuit designer to wrap the amplifier with such a circuit.
The gain of the 'operational amplifier circuit' is set by the circuit with which the designer has surrounded the 'operational amplifier".
Usually that gain is of the form (Zfeedback) / (Zinput) which defines the mathematical operation that the 'operational amplifier circuit ' will perform on an input. It's called "closed loop gain" of the operational amplifier circuit.
Here's how and why it works:
Paraphrasing Jeff',
"It is the duty of the circuit designer to surround his operational amplifier with a circuit that let's it force its inputs equal.
Else his circuit cannot 'operate'. "
Think about that for a second
since the amplifier has preposterously large gain.,
IF :
its output is to lie between the power supply rails
THEN
its inputs must be so close together they're effectively equal.
THAT is backward thinking and is hard to accept .
Work on it for a moment. Never underestimate the power of sideways thinking(john keasler) .
So, the output will stop moving when and only when the inputs become 'equal" to one another.
Should the output overshoot , that'll propagate to the input so output will reverse and move back to rebalance the inputs.IF power supply rails are + and - 15 volts
and, Aol is 10^5
and output lies between the rails, ie circuit is 'operating' instead of saturated
THEN the inputs must be within 150 microvolts* of one another or the circuit is not operating, it's saturated at one of the power supply rails,
if one input is at 1 volt the other must lie between 0.99985 and 1.00015 , more digits than on the average voltmeter
*(150 microvolts is 15/10^5, Vsupply/Avol)
So to find gain of the operational amplifier circuit, one writes KVL for voltage at both inputs and sets them equal.
don't like it when people post "shortcuts", mental tricks. etc before the basic principles are explained.
Setting the inputs equal gives a wrong answer for an opamp with a gain of 1000 (as stated in the OP). PERIOD!
V+ = 1 (assume for the moment)
V- = Vout/2
So, what is Vout equal to? Why take shortcuts when the correct answer is so simple? (1000/501)
No iterations, no steps, no assumptions other than no delays.
Input at 0, output at zero
Apply 1v step, output becomes 1000/501. End of story.
You can go on to say input differential is 1/501 volts if you want.
meBigGuy said:
(1000/501)
Where'd that come from ?
Every introductory opamp course i ever saw starts with two assumptions:
zero input current, ie infinite Zin
infinite gain, ie zero input differential voltage which makes inputs equal.
Let's see by how much the answer is "wrong"
V- = Vout/2
Setting V+ = V- = Vout/2
and using your V+ = 1
then 1 = Vout/2
vout = 2.000
If one wishes to account for Avol less than infinite he should use a more exact formula like yours
1000/501 = 1.996
Difference is 2.000/1.996 = 1.002, two parts per thousand
And it's all due to the initial assumption about opamp gain, infinite vs 1000.
The OP specifically specified 1000 gain. That means that assuming they (+, -) are equal is incorrect.
V- = Vout/2
Vout/1000 = 1 - Vout/2
Vout = 1000 - 500Vout
501Vout = 1000
Vout = 1000/501
Why make erroneous assumptions when exact answers are so easy and we are trying to teach?
Isn't your assumption that the amp has no input current erroneous? The exact answer taking input current into account is also easy.
It is not erroneous, just not included in the OP's question.
I listed my assumptions in post 8, and I think I answered the OP's question.
"Assume the amp is instantaneous and has no input current, the loop has no capacitance or inductance."
All of those assumptions are "non-real-world" but provide a foundation to answer the original question, which included Aol = 1000.
It is easy enough to add whatever additional real world characteristics you want to consider. If the OP wants to add further constraints, then I'm fine with that. My main objection has been all the mental "iteration" stuff that has no basis. If you want to deal with time response, then you need differential equations. The opamp does not "find equilibrium" in the imprecise way that several have described it.
The two assumptions made in the two "opamp rules" as usually given are v+ = v-, and input current = zero.
If you're going to make a case for not ignoring the error in one of the assumptions, since you're trying to teach, why ignore the error due to the other when you can easily make the teaching more complete? You could go beyond what the OP asked and teach a little more, heading off the OP's possible future question about input current.
You can hypothesize all you want about what he might ask next. Feel free to make all the assumptions you want and develop the solutions. I'll read them! Try actually contributing.
The OP specified Aol = 1000, so assuming V+ == V- is wrong. Period. End of discussion.
meBigGuy, do you remember how we proceed to find out if a certain operating point (I do NOT refer to opamps only) is stable or not?
I think, what we are doing is a kind of "iteration": We assume a certain disturbance (shifting of the operationall point) and then we ask: What is the result?
Will this shifting supports (enhance) itself or not?
(One typical example comes into my mind: Steady-state oscillator amplitudes using describing functions).
This is the classical method primarily for systems which have two or more current-voltage relations fulfilling the rules of electronics.
No differential equations are necessary to explain why and at which value the output settles..
Therefore, I think it is correct to say "The opamp finds its equilibrium".
After the opamps power supplies are switched on you can observe how the output voltage moves (searches) until it remains fixed.
Now we are getting into discussions about the benefits of various models.
Some models are closer to realworld op-amps than others. But no model is a real world op-amp.
So the value of any model is a judgement call. Some will be closer to the OP. Some will give answers closer to the real world. Some will be easier to understand or more broadly applicable.
We should all be willing to use the appropriate models for the task at had. A broad model helps us choose topologies and parts. More precise models give better answers when tolerances are tight.
Thanks to everyone who provided a model.
Ahhhh,, okay fair enough.
Thanks for the derivation, too.
