How does butane gas flow from a canister to refill a lighter?
  • Thread starter Thread starter M.Kalai vanan
    vapor pressure
The discussion centers on the mechanisms involved in the flow of butane gas from a canister to refill a lighter. Participants explore whether gravity or vapor pressure is the primary driving force behind this process, and they seek clarification on how the transfer occurs under different conditions.
  • One participant questions whether the flow of butane is due to gravity or vapor pressure, noting that a torch held above the canister challenges the gravity argument.
  • Another participant suggests that if vapor pressure is the reason, it should be the same in both tanks, prompting further inquiry into the mechanics of the transfer.
  • A later reply expresses confusion about the filling process, particularly regarding the role of atmospheric venting in the lighter tank and how it relates to the volume of fuel entering and exiting the tanks.
Participants do not appear to reach a consensus on whether gravity or vapor pressure is the primary factor in the flow of butane gas, and the discussion remains unresolved regarding the mechanics of the transfer process.
There are unresolved questions about the assumptions regarding pressure differences and the conditions under which the transfer occurs, particularly concerning the venting of the lighter tank.
M.Kalai vanan
when butane lighters are refilled by external canister, HOW and WHY butane gas flows from canister to lighter
Is it due to GRAVITY or VAPOR PRESSURE?
If GRAVITY is the reason I have posted a link where torch is held above the canister?
If it is vapor pressure, it is going to be same is both the tanks ?
Some one please explain HOW this actual transfer is happening ?
Thanks
But I still don't have a clear picture
If the lighter tank is vented to atmosphere causing a pressure drop between canister and tank,
Will then the
volume of fuel exiting the tank= volume of fuel entering the tank from canister
Then how does it gets filled
  • · Replies 42 ·
36K
  • · Replies 18 ·
13K
  • · Replies 31 ·
12K
  • · Replies 160 ·
12K
9K
