How does g-force have x, y and z components?
  • Level: High School
  • Thread starter Thread starter solarmidnightrose
    G-force G-forces
12 replies · 15K views · last reply
solarmidnightrose
TL;DR
What is G-Force?
I've been to the amusement park recently, and one day I decided to use an app (Physics Toolbox), to collect some data.
I downloaded the data, and it gave it to me in a .csv format. This table of data showed that there were x,y and z values for G-Force.
I don't understand how G-Force has x,y and z components/aspects?
Please help me to understand this.
Thank you.
Think about being in a car that's going up an incline, around a turn, and accelerating all at the same time.
Okay, so I've thought about what you've said... and this is how my brain interprets it:
The car is doing 3 different things all at once... If G-force is like the car that can do three things at once, then that would result in it having an x,y and z component.​
G-Force can travel in different directions? (is that what the message is?)​
Well, thank you phinds for your input, but I still don't understand what x/y/z components of G-Force actually are? In what direction do they act?
Also, to calculate the total G-Force, how would you do that? Would you have to use Trigonometry or is there some special formula specified for G-Forces?
Thanks.
It all depends on what 'reference frame' you are using. Your App is traveling with you its reference frame will be a local one and, if you line it up so that its screen faces forwards and the bottom is towards the floor of the car then those are the xyz directions. That would be the easiest frame in which to consider your ride. When you are stationary, only the z (down to the floor, say) would have a g value (giving you your weight). As you accelerate in a straight line, the y (fore and aft) would start to show a backwards g value and when you enter a bend, you will have a g component towards the outside of the curve. The signs of these accelerations can be confusing and they need to be consistent amongst themselves and with how you 'feel' them. You 'feel' a centrifugal force because the car is pushing you into the curve etc..
The overall g force magnitude would be g = √(gx2 + gy2 +gz2) and the direction would be found by Trigonometry. That involves specifying the angles in your Cartesian xyz axes and you can think of it in terms of Spherical Polar Co ordinates - which you may or may not want to get into. This link will do it for you (you enter the xyz co ordinates into the box at the top and the spherical values turn up there. The diagram at the bottom of the page tells you how the angles are defined. Try some simple values and check that the results make sense to you.
PS Your data will not be consistent with the above unless you happened to be holding the phone the way I describe but, if y ou held the phone steady, you could use the above calculator to tell you which way is 'up' when you started off.
Summary: What is G-Force?
Do a google search for vector components.
This is an app on your phone, right? The accelerometers are fixed to the phone. On my Samsung, when holding the phone flat, x is to the sides, y is forward/back and z is perpendicular to the screen.
Thank you.
If you push an object, it accelerates in the direction you are pushing it. Now, suppose that you are sitting in a car with your back against the seat. The car gets a push from behind (say, another car hits it). Then the car goes forward. But you don't--at least, not immediately. Because nobody is pushing you. But the seat that you're sitting in is attached to the car, so it moves forward, pushing against your back. So you feel the seat pushing against you. Your brain, which is used to your being held down by gravity interprets what's happening as some kind of artificial gravity pulling you back into the seat. But that's not what's really happening---it's really the seat pushing forward into you.
From your point of view, you can think of the car as at "rest" and there is a weird kind of fake gravity pulling you back into the seat. That fake gravity is what people call "g-forces". It's just the opposite of the force of the seat pushing against you, just re-interpreted by your brain as fake gravity pulling you back into the seat.
It's a vector; it has a direction and a magnitude. The direction is the opposite the direction your car is being shoved.
Yes, this is all beginning to make sense to me now. Once I clicked the link you attached it all began to fall into place.
Thank you
Yep this is an app on a phone. And I get the same results as you have stated.
Thanks.
A wonderful explanation I never would have thought of all by myself. I now understand this new concept of g-forces.
Thank you @stevendaryl
sophiecentaur said:
@solarmidnightrose
Do you remember doing the parallelogram of forces in your youth? That's simple vectors in 2D. It extends to 3D in the same way.
Hi @sophiecentaur I have only begun learning about 2D/3D vectors earlier this year, so this is all very new to me. Nevermind that-this is very good revision for me.
The notion of Components of a Vector can be a hard one if it's not presented in the right way; resolving forces into components is somehow harder than combining two forces. So - one thing at a time. :smile:
