How Does Inductance Affect DC Circuit Behavior?
The discussion revolves around the behavior of a DC circuit containing an inductor and a resistor. Participants are exploring the effects of inductance on circuit parameters such as time constant and voltage drops across components.
  • Participants share calculations for time constant and voltage drops but express uncertainty about determining the resistance of a new coil. Some participants question the validity of their calculations and seek clarification on the relevant equations.
Several participants have provided calculations and insights, with some confirming the results of others. There is ongoing exploration of the relationship between resistance, inductance, and time constant, with new participants seeking guidance on specific aspects of the problem.
Participants are working under the constraints of a homework assignment, which may limit the information available and the methods they can use. There is a mention of a specific time constant value that alters the resistance calculations.
jimmy4
1. An inductor of negligible resistance and an inductance of 0.2 H is
connected in series with a 330 Ω resistor to a 12V d.c. supply.
Determine:
(a) the time constant of the circuit
(b) the voltage drop across the inductor after two time constants
(c) the voltage drop across the resistor after three time constants
(d) the resistance of a 0.2 H coil used to replace the inductor if the
circuit’s time constant falls to 0.55 ms.
I have calculated A, B, and C, however I am struggling with D.
(a) 0.606ms
(b) 1.62V
(c) 11.4V
2. relevant Equations. resistance = inductance / time constant
Determine:
(a) 0.606ms
(b) 1.62V
(c) 11.4V
Given the new time constant value, what is the total resistance? (Hint: use the formula you gave as a relevant equation).
If the external resistor comprises 330 Ω of that total resistance, how much should be ascribed to the new coil?
R = 0.2H/0.55ms
R = 36 Ohms
Not sure much should much should be ascribed to the new coil, or how this is calculates into the equation
R = 0.2H/0.55ms
R = 36 Ohms
That resistance looks a bit too small. Check your units' powers of ten.
R = 360 Ohms
Original Resister = 330 Ohms
Therefore resistance through the coil = 30 Ohms
jimmy4 said:
R = 360 Ohms
That looks fine.
Cheers gneill thanks a lot mate.
Hi guys, sorry to butt in on this post but I am currently completing this question and I'm struggling with b & c. I've worked through the lesson but cannot see any equations that I can use for the voltage drop across the resistor or the inductor. Would either of you be able to point me in the right direction? I've been stuck for a few days now so any guidance would be greatly appreciated. Thanks in advance.
The equation you are after is i=I[1-e^-Rt/L] and you will need to calculate I first before you can use the equation
