How does inertia tensor scale when a CAD model is resized?
2 replies · 5K views · last reply
alexanderBuzz
Hi everyone,
I have the following problem in my hands, which I don't know how exactly to address.
Let's assume that from any CAD(Solidworks, Catia), I obtain the inertia tensor of my model (impossible to calculate by hand btw).
I_full=[Ixx Ixy Ixz
Ixy Iyy Iyz
Ixz Iyz Izz]
I know if I change the mass of my model, the inertia tensor will scale linearly with it.
But what If I scale my model to half-size, all dimensions? The mass probably goes by 1/8, since it's proportional to volume. Maybe the other factor would be 1/4 (α r^2).
So would the correct Inertia scaling factor be?:
I_half=1/4*1/8*I_full
Cheers!
UltrafastPED said:
It must vary jointly with the mass and the distribution; for example consider how the simple inertia of a thick rod changes under your conditions: http://hyperphysics.phy-astr.gsu.edu/hbase/mi2.html
Thanks you!
It proves my derivation, if assumed constant density between the scaled object and full-size object.
by definition:
[tex]I=\int_V \rho r^2 dV[/tex]
if r1-> ar ( scaled by a factor a) dV1->a^3dV
replacing on the above equation:
[tex]I1=\int_V \rho a^2 r^2 a^3 dV = a^5 \int_V \rho r^2 dV -> I1=a^5 I[/tex]
again, assuming that the mass distribution remains constant.
Correct?
