How does mass M enter the friction force equation for connected blocks?
  • Thread starter dawn_pingpong
    Friction
8 replies · 2K views · last reply
dawn_pingpong
Please see attached
Ff=μFn,
F=ma
(a) The blocks can have the same acceleration due to static friction.
consider the 2 blocks on the left: Ff=fmg
then consider the 2 blocks on the right: Ff is also fmg? I am rather confused at this point... how does M come into the equation? because the answer for part (a) is 2(M+m)/(M+2m)f. There is no g anywhere in the equation, though from the equation, friction is to the normal, which is mg?
THank you!
  • Two physics diagrams of four blocks on a smooth horizontal surface, each pair of top blocks (mass m) connected by a rope over bottom blocks (mass M); force F pulls the right bottom block in (a), force F' pulls the top right block in (b).
The frictional force is given as fs. It is equivalent to mgμ.
It is a system of 4 objects in unison, one identical acceleration.
yeah okay, but how to do the question? Can give me a head start? Thanks!
The static friction force created by small mass m on top of the right side will pull both itself and the 2 blocks behind it.
As a body of 4 blocks there is only one the accelerations value.
sorry, I don't really get what you mean, please elaborate... So for the small mass on the right, f value must be (m+M)f?
If the blocks are all to move with the same acceleration then the small mass [itex]m[/itex] relative to the large mass [itex]M[/itex] must be stationary. I suggest drawing a free body diagram for the [itex]m, M[/itex] system, being careful to get the direction of the frictional force correct.
Net external force applied on a system always equals to total mass of system into its acceleration .
Okay, I think I know...
So the whole thing F=2(M+m)a ...(1) (as stated by azizlwl)
the greatest friction is between the blocks on the left, so fs=(2m+M)a ...(2) (thanks azizlwl!), because the bottom block on the right need not be considered. So F/fs=2(M+m)/(2m+M), and F=2(M+m)f/(2m+M)
Then for the 2nd part, F=2(M+m)a ...(1) still,
then f is only for the block M on the right, thus f=Ma,
by the same reasoning, F=2(M+m)f/M.
Yay thanks guys! Any tips for force analysis (and consider which few objects as a system?)
