How Does Measurement Affect Uncertainty in Quantum Mechanics?
8 replies · 2K views
dRic2
I'm having trouble trying to remember this:
suppose I have an operator ##A## and an eigenfunction ##\psi = c_1 \psi_1 + c_2 \psi_2## for ##A## so that
$$ A\psi = a\psi$$ The expected value is
##\langle A \rangle = \langle \psi|A|\psi \rangle = a##
After a measurement ##a## can be ##a_1## or ##a_2## and the probability of a particular outcome is ##|c_i|^2##.
Let's say the outcome of my measurement is ##a_1##. Now I'm certain about this, right? The uncertainty of ##a_1## is now ##0## because I measured it and so I forced the particle to be in the state with eigenvalue ##a_1##.
Now suppose I take the operator ##B## incompatible with ##A## and I try to evaluate:
$$\langle B \rangle = \langle \psi_1|B|\psi_1 \rangle = b$$
(because I know that after my measurement the particle is in the state ##\psi_1##).
This last operation is totally meaningless because, since ##a_1## is certain, the uncertainty of ##b## should be ##\infty## so, even if I can calculate an "expected value" for ##B## it has no physical significance because its uncertainty is ##\infty## , right ?
Is it correct?
Thanks
Ric
There are too many misconceptions there to address them all. Let's take the central issue.
If a system is in the state ##\psi = c_1\psi_1 + c_2\psi_2##, where ##\psi_1, \psi_2## are eigenstates of operator/observable ##A##, corresponding to eigenvalues ##a_1, a_2##, then:
##\langle A \rangle = \langle \psi | A | \psi \rangle = |c_1|^2 a_1 + |c_2|^2 a_2 = a##
And the uncertainty in ##A##, can be calculated as:
##\sigma_A^2 = \langle (A - a)^2 \rangle ##
If observable ##A## is measured, and the result is ##a_1##, then the system is in the state ##\psi_1##. The expected value of ##A## is now ##a_1## and there is no uncertainty in ##A##: for the state ##\psi_1##, we have ##\sigma_A^2 = 0##
Now, ##\psi_1## will be a superposition of the eigenstates of operator/observable ##B##. For example:
##\psi_1 = d_1 \phi_1 + d_2 \phi_2 + d_3 \phi_3##
Where ##\phi_1## etc. are eigenstates of observable ##B##.
A measurement of ##B## (of the system in state ##\psi_1##) will return the eigenvalues ##b_1, b_2, b_3## with probabilities ##|d_1|^2## etc. And the uncertainty in ##B## can be calculated from this.
On a second point:
You may be thinking of the uncertainty in position and momentum. But the eigenvalues of those observables form a continuous spectrum and are not covered by the standard linear algebra (for a discrete spectrum). The states are not physically realisable and, if you assume the system is in an eigenstate of position, then the uncertainty in momentum is undefined (infinite, if you like).
If a system is in the state ψ=c1ψ1+c2ψ2ψ=c1ψ1+c2ψ2\psi = c_1\psi_1 + c_2\psi_2, where ψ1,ψ2ψ1,ψ2\psi_1, \psi_2 are eigenstates of operator/observable AAA, corresponding to eigenvalues a1,a2a1,a2a_1, a_2, then:
⟨A⟩=⟨ψ|A|ψ⟩=|c1|2a1+|c2|2a2=a⟨A⟩=⟨ψ|A|ψ⟩=|c1|2a1+|c2|2a2=a\langle A \rangle = \langle \psi | A | \psi \rangle = |c_1|^2 a_1 + |c_2|^2 a_2 = a
And the uncertainty in AAA, can be calculated as:
σ2A=⟨(A−a)2⟩σA2=⟨(A−a)2⟩\sigma_A^2 = \langle (A - a)^2 \rangle
If observable AAA is measured, and the result is a1a1a_1, then the system is in the state ψ1ψ1\psi_1. The expected value of AAA is now a1a1a_1 and there is no uncertainty in AAA: for the state ψ1ψ1\psi_1, we have σ2A=0σA2=0\sigma_A^2 = 0
This is clear to me. It may not seem because I think I phrased it very badlyBut I don't understand this:
If ##[A, B] ≠ 0## how can ##\psi_1## be an eigenfunction for ##B##?
Please correct me if I'm wrong: If ##\psi_1## is a linear combination of ##ϕ_1, ϕ_2, ... ϕ_n ## and ##ϕ_i## are eigenfunctions of ##B##, ##\psi_1## should be an eigenfunction of ##B##.
That is wrong. A well-behaved operator will have a spectrum of eigenfunctions that span the space. So, every function can be expressed as a linear combination of eigenfunctions of that operator. In QM it is generally assumed that each observable operator under consideration has this property: a complete set of orthogonal eigenfunctions (that span the space).
In the case of a finite dimensional vector space, this can be proved for "normal" operators. This is the finite dimensional spectral theorem.
PS in my example:
##B\psi_1 = d_1B\phi_1 + d_2B\phi_2 + d_3 B\phi_2 = b_1 d_1 \phi_1 + b_2 d_2 \phi_2 + b_3 d_3 \phi_3##
And ##\psi_1## is not an eigenfunction of ##B## unless ##b_1 = b_2 = b_3##.
No, a sum of different eigenstates is not in general an eigenstate. Suppose that ##\phi_1## and ##\phi_2## are eigenstates of ##B##, with eigenvalues ##\beta_1## and ##\beta_2## respectively. Now, ##B(\phi_1+\phi_2)=\beta_1\phi_1+\beta_2\phi_2##, and that cannot be a multiple of ##\phi_1+\phi_2## except in the special case ##\beta_1=\beta_2##.
Thank you, very much. I will study again this topic more carefully
I was actually thinking about ##L_x##, ##L_y## and ##L_z## and their uncertainties in H atom
