How Does Mercury's Compression Affect Heat Transfer and Energy?
Winzer
The pressure on 0.01 litres of mercury is increased reversibly and isothermally
from zero to 1000 atm at room temperature (293 K). Mercury has a coefficient
of volume expansion β = 1.82 × 10−4 K−1 , and an isothermal compressibility
κT = 4.02 × 10−11 Pa−1 . Note: 1 atm= 1.013 × 105 Pa. Assuming that the
volume, V , changes very little, find
(i) how much heat is transferred in the compression;
(ii) the work done during the compression;
(iii) the change in internal energy.
[tex]T dS= C_p dT -\beta V dP[/tex]
[tex]\oint \frac{\def\dbar{{\mathchar'26\mkern-12mu d}Q} <br /> \dbar}{T}=0[/tex]
[tex]\def\dbar{{\mathchar'26\mkern-12mu d}Q} <br /> \dbar=C_v dT[/tex]
I am attempting to find the final temp so I can implement: [tex]\def\dbar{{\mathchar'26\mkern-12mu d}Q} <br /> \dbar=C_v dT[/tex]
Since the process is reversible, and under a complete cycle [tex]\oint \frac{\def\dbar{{\mathchar'26\mkern-12mu d}Q} \dbar}{T}=0[/tex] I set [tex]dS=0[/tex]. Getting [tex]C_p \int \frac{dT}{T}=\beta T V \int dP[/tex] Is this correct so far?
Your first and last equations doesn't look right. Check your units and your T's.
