How Does Opening a Valve Affect the Force Due to Fluid Pressure?
  • Context: Undergrad
  • Thread starter Thread starter KingBongo
    Force Spring Valve
The discussion centers on the application of Bernoulli's Principle to analyze the force exerted on a valve in a pressurized pipe filled with liquid. When the valve is closed, the force is calculated using the formula F = P*A, where P is the static pressure and A is the area of the valve. However, when the valve is opened, the force is influenced not only by static pressure but also by the kinetic energy of the flowing fluid, necessitating a momentum rates approach to determine the net resultant force. This analysis is crucial for understanding fluid dynamics in control engineering contexts.
  • Bernoulli's Principle for incompressible fluids
  • Static and dynamic fluid pressure concepts
  • Momentum rates in fluid flow analysis
  • Basic thermodynamics principles
  • Study advanced applications of Bernoulli's Principle in fluid mechanics
  • Learn about momentum conservation in fluid dynamics
  • Explore control volume analysis in fluid systems
  • Read textbooks on thermodynamics and fluid mechanics for deeper insights
Engineers, particularly those in control engineering and fluid dynamics, as well as students seeking to deepen their understanding of fluid pressure and flow dynamics.
KingBongo
I have been thinking about this a lot. It is about conservation of energy. A simplified analysis using Bernoulli's Principle for one-dimensional incompressible liquid fluids should be good enough to gain some understanding (at least for me). Let us also neglect gravitational effects.
Assume you have a pressurized pipe filled with liquid plugged by a spring loaded valve at one end. What is the (fluid) force on the valve?
I understand that when the valve is CLOSED the force would simply be F = P*A, where P is the STATIC pressure and A is the Area on the valve. But what if you OPEN the valve a little so that liquid begins to flow? Is the force on the valve determined by the STATIC pressure only, or is it determined by the TOTAL pressure, i.e. including the kinetic part of the fluid motion?
What is the Force? Please help.
Make sure you state exactly what you know from the problem. A problem like this can be solved many ways if you know most of the information, but a homework problem usually gives you the bare minimum and can only be solved one way.
If fluid is flowing through a control volume, a valve for example, the net resultant force on the valve is equal to the difference in momentum rates (mass flow rate times velocity) between the inflow and the outflow.
genghiskron:
Thank you! Well, I am actually not a student. I am a Doctor in control engineering. But this flowing liquidsthing is killing me. No wonder, since I only took a basic course like forever ago, :) Is it thermodynamics we are talking about here?
Are there any good books I could read about this? A little bit more advanced would be just fine.
Further questions:
I suspect the "momentum rates approach" can only be used if the valve is open, because else there would be no flow at all. Is it so?
  • · Replies 20 ·
  • · Replies 18 ·
  • · Replies 48 ·
  • · Replies 73 ·
17K
