How Does Particle in a Box Relate to Quantum Mechanics?
  • Thread starter Thread starter Zeynaz
    Box Particle
The discussion revolves around the concept of a particle in a one-dimensional box within the context of quantum mechanics. The original poster expresses confusion regarding the relationship between potential energy, kinetic energy, and the calculations involved in determining the energy and velocity of a particle confined in such a potential well.
  • Participants discuss the application of formulas related to energy and velocity, questioning the validity of their calculations and the assumptions made about potential energy within the box. There is an exploration of the implications of using the mass of the ball versus the mass of an electron.
Some participants have identified calculation errors and are seeking clarification on the relationship between potential energy and kinetic energy in the context of the problem. There is ongoing exploration of the assumptions regarding potential energy inside the box, with some guidance provided about the nature of potential energy in this scenario.
Participants are working under the assumption that the potential energy inside the box is zero, which is a fundamental aspect of the particle in a box model. There is also mention of the need to adhere to specific homework rules regarding the presentation of calculations.
Zeynaz
A ball of mass 3 g is trapped in a box with infinitely high walls. The width of the box is 8 cm.
a) Calculate the speed of the ball when it is in the ground state of the box
b)Estimate the quantum number n if the ball is moving with a constant speed of 2 m/s in the box
Ek= 1/2 (m)(v)^2
E=hf
E-n= (n^2*h^2)/ (8*m*L^2)
I am having difficulties understanding this concept. Particle in a box (as far as i understood) shows that the electrons or particles need a certain about of potential energy to escape the one-dimensional potential well. I think its pretty similar to the concept of the electons and ionising energies. (correct me if i am wrong).
so in question a) i tried to use the formula by just using the values i knew, L=0.08 m and m=3e-3 kg. I also took n=1.
As a result E=4.32e-30 J. When i equate this energy with KE. I get a small velocity of 3m/s. (The correct answer is 1.0e-30 m/s)
I am not sure how to find the right answer.
Also, because the ball is in a box with infinitely high walls, it should have an infinite potential energy thus inifinite KE. So how is it possible to find a value for this.
can someone explain/help?
thanks!
It's difficult to see how such a tiny energy could equate to ##3 m/s## for an object of ##3g##.
The potential is 0 inside the box.
oh right i used m as the electron but i had to use the mass of the ball.
this gives me v= 5.37e-14 m/s which is still not the correct answer.
Also, if the potential is 0 inside the box, E=KE.
You need to show your calculations. Although it looks like you've simply not squared Planck's constant.
yes you were right i made a mistake with my calculations.
then in this case my only question would be;
would it be possible to say that E(n)= PE+KE= hf?
Thers is no potential in the box. That's a basic assumption about the problem. The only potential is the "infinite" potential outside the box, which stops the particle getting out.
alright, thanks!
  • · Replies 30 ·
9K
  • · Replies 18 ·
