How Does Rotating a Wire in a Magnetic Field Affect Force and Current?
The discussion revolves around the effects of rotating a wire within a magnetic field, specifically focusing on the relationship between the angle of rotation, the length of the wire in the magnetic field, and the resulting force experienced by the wire. The context involves a magnetic field of 1.4 T and a current of 2.0 A flowing through a long wire.
  • Participants explore the implications of rotating the wire in the horizontal plane and question how this affects the length of the wire within the magnetic field and the angle of interaction with the field. There is uncertainty about the definition of "rotated in the horizontal plane" and how it influences the force on the wire.
The discussion is ongoing, with participants questioning the effects of rotation on the force experienced by the wire. Some have suggested that the force may change due to the angle of rotation, while others are examining how the length of the wire in the magnetic field and the sine of the angle factor into the force calculation.
Participants note that the problem statement lacks detailed information, leading to various interpretations and assumptions about the setup and conditions of the wire and magnetic field.
EgpYo
A magnetic field of 1.4 T [N] is 4.0m wide. A very long wire crosses the field. The current in the wire is 2.0 A [W].
What would happen if the wire is rotated slightly in the horizontal plane?
F = ILBSinx
I don't understand what it means by "rotated in the horizontal plane". If it was moved left or right, L would increase because the wire isn't moving straight across the electric field. However, it says the current in the wire is moving West which confuses me.
Is it saying that the wire is lifted to create an angle with the surface it is on?
The wire is sitting on a horizontal table, current travels leftward (West), from right (East).
The Magnetic Field points forward along the table (Northward).
In this situation, only 4 meters length of the wire (current) is in the B-field,
so the magnetic Force applied to the current is F = ILxB = ILB sin 90 (downward).
The wire stays horizontal as it rotates, and the current rotates with it
... suppose, to 10deg North of West.
the wire is "very long" ... much longer than 4 m ; is more wire in the B-field now, than was in it before? Is the extra length made up for by sin 10?
Thats all it says. I actually wrote the question wrong, it says:
What will happen to the force on the wire if the wire is rotated slightly in the horizontal plane?
Is this the total information you have re this problem? Is it from a textbook?
yes to both
So, if the wire is rotated by 10o , so it doesn't cross "straight West" across the B-field's width,
does the Force increase, decrease, stay the same ... and why? I would stick to Force strength (ie, magnitude)
L increases so the force should increase but it is also not perpendicular to the magnetic field so I don't get it.
IL x B means IL B sin θ ... θ is now 80°, rather than the 90° that it used to be ;
but the length is a *bit* longer (along the trig triangle hypotenuse; 4m is the long leg).
  • · Replies 21 ·
  • · Replies 35 ·
