How Does Siphon Work? Explanation & Principles
  • Context: High School
  • Thread starter Thread starter jnlbctln
    Work
The siphon operates based on the principles of gravity and hydrostatic pressure, where atmospheric pressure pushes liquid up the tube into a region of reduced pressure created by the falling liquid on the exit side. The siphon requires an initial pump to start the flow, as it creates a pressure differential between the two arms of the siphon. The discussion clarifies that Bernoulli's principle does not play a significant role in the basic functioning of a siphon, as it can operate even at zero velocity. The key takeaway is that the difference in gravitational forces acting on the liquid columns is the primary driving mechanism behind siphon operation.
  • Understanding of hydrostatic pressure and its effects
  • Familiarity with basic fluid dynamics concepts
  • Knowledge of atmospheric pressure and its role in fluid systems
  • Basic principles of gravity and its influence on fluid movement
  • Research the mechanics of siphons in various fluid types
  • Explore advanced fluid dynamics concepts, including Bernoulli's principle
  • Investigate practical applications of siphons in engineering
  • Study the effects of atmospheric pressure on fluid behavior in different environments
Students in physics, engineers working with fluid systems, and anyone interested in the principles of fluid dynamics and siphon mechanisms.
  • #31
OmCheeto said:
The vacuum siphon video implies that the chain analogy is correct, in that instance.
Does it? The chain analogy is all about the heavier column pulling up the lighter column. The guy in the video doesn't even bother about the liquid levels in the inverted U-tube.
  • #32
Whatever be the pressure of the atmosphere, or even if there is no atmosphere, the difference of hydrostatic pressure at the points B and C at the top for a given siphoning setup will be the same.
  • #33
There is no mention of the actual tensile strength of that "ionic liquid". How many metres would the tension support or was the inverted U that we saw as much as the tension would support?
The video was an interesting diversion but it says very little about real siphons with real liquids. It has been shown that a siphon works even with a bubble in it so that evidence shows nothing other than how a very novel liquid behaves. Plumbers use water and barometers use mercury; real, everyday liquids and it is those that are of real interest.
  • #34
Found this today: The great siphon debate continues.
http://www.nature.com/srep/2014/140422/srep04741/full/srep04741.html
Over the last few years there has been controversy over how siphons work3, 4, 5, 6, 7, 8, 9. Two competing models have emerged. In one model, water flowing out of a siphon generates a low-pressure region at the crown so that atmospheric pressure pushes water into the siphon. In another, the weight of water flowing out of a siphon pulls water into the siphon via liquid cohesion.
The siphon debate has also had an impact in the field of botany in relation to how water can rise above the 10 m siphon limit in trees10. This implies some kind of continuous link between water entering the roots and transpiring through the leaves. In the field of biomedicine there is controversy over whether the siphon principle operates in the human and other circulations11.
An argument often used in support of the atmospheric model of the siphon is the fact that the maximum height of a siphon is almost the same as a barometer. The experiment described in this paper explores the boundary between the siphon and barometer.
  • #35
Firemen all know of the ten metre limit to up-hill pumping with a lift pump (quite a bit less than ten metres, actually). Also, we have all seen a mercury barometer at work. So the idea of tension cannot apply under all circumstances.
I have a problem seeing any inherent difference between a syphon and a simple inverted tube. After all, if you were to introduce a vertical wall in a tube, with a gap at the top, you would have a 'syphon'. If the syphon were to be working above the limit imposed by density and then you removed the wall, would you expect the column to stay that high?
I have read odd bits about tension in liquids and there are some pretty high values quoted. This tension could, presumably, be broken by any nucleus (as with super heated water). So, given the right circumstances (narrow, smooth, clean tube), why shouldn't the ten metre limit be broken?
Perhaps there is, in fact, no conflict at all. It's just that you get different results under different conditions. (Happens quite a lot in Science)
  • #36
hi Andy
thanks for the video ... that lead me to a couple of hours of video watching from the Periodic Table of Videos
collection ... very informative !
Cheers
Dave
  • #37
The 'waterfall' effect must be fascinating to watch. Is there a movie available to see?
  • #39
Ignoring compressiblity, pressure increases linearly with depth from the upper surface of a fluid. At any fixed height above the ground, the pressure at that height in the container with the higher upper surface of fluid is greater than the pressure in the container with the lower upper surface of fluid. This means that within the siphon, there's a decreasing pressure gradient component as fluid flows from the higher upper surface container to the lower upper surface container, providing the force that drives the fluid, even if the siphon rises above the fluid upper surfaces.
The height of the intake and outlet ports of the siphon doesn't matter, as long as both ports are submerged.
For the botany case, I would assume osmosis is the main factor in drawing water upwards (or outwards) through any plant, regardless of height.
  • #40
Hello again, so I've conducted experiments measuring the rate of flow of a siphon changing various things like the ratio of the lengths of tubing and the level of water. I found that the only times I got exactly the same rate values was when the difference in height between the lever of water and the receptor end of the tube were equal. Therefore I deduced that this height must be important. Then I graphed the energy levels using this height. Because velocity is perportional to the root of the height. It yeilded a straight line graph which proves that this is true. Therefore the only thing that drives a siphon is it's potential energy. I realize this is not a complete explanation but I think it's close to the truth. An interesting thing is that the siphon still ran when the two lengths of tubing were the same or the shorter and longer sides were reversed as long as the water level was higher than the end of the recepter tube, so this led me to dismiss the gravity pulls on the longer arm more than the shorter arm theory. Any thoughts?
  • #41
As long as both ends of the siphon are submerged, and the siphon is filled with fluid (no air or vacuum gaps), the fluid in both containers will flow until the height (above ground) of fluid in both containers is equalized (or until the surface of the higher fluid drops below the receptor port of the siphon). The common expression for this is "fluid (or water) seeks its own level" .
  • #42
Why are they seen as "competing"? Isn't it the case that the maximum height of a syphon is the combination of the two?
  • #43
The effect of gravity on each part of the fluid is the same, near the ground. It would be a good idea to start by reading the basics about hydrostatic pressure. The pressure in each column is due to its height and the fluid density. The factors governing the flow rate are not just the pressure difference but the fluid dynamics so you would not expect that the flow rate would only be a result of the two heights involved. Using different tube thicknesses could show that the height is not the only factor.
I don't understand why you got any flow at all when the two levels were equal. (?)
  • #44
Sorry I meant when the difference which was different from zero was the same in different experiments. By different experimemts I mean one where I just varied the level of water and another where I shifted the tube to change the ratio of heights on the two sides.
  • #45
I don't think that both sides need to be submerged just the one with the water you'd like to displace.
Can someone clarify what the meaning of negative pressure is? Is it less than atmosphereic pressure?
  • #46
Can someone clarify what the meaning of negative pressure is? Is it less than atmospheric pressure?
If the lower tube is not submerged, a bubble can form and let all the liquid out of the long arm of the siphon.
All pressures are greater than zero and a 'negative' value is relative to atmospheric pressure.
  • #47
This is correct, of course. But in practice, if flow rate is sufficiently high and the tube width (and, therefore the bubble size) is sufficiently low then the bubbles do not rise faster than the outflow and the siphon continues to work in spite of this possibility.
  • #48
If either end of the siphon is not submerged, then air could travel up the exposed opening and stop the siphon from working. This would be an issue of the siphon diameter and the rate of flow.
  • #49
Thanks:D How would the air bubble form? If we are thinking of a practical siphon air can't push up the undubmerged receptor end because atmospheric pressure acts upon both ends so it is balanced. I'm thinking of an incompressible liquid here but even if the liquid was compressible I doubt it would mattter :/
  • #50
If the tube diameter is big enough, a horizontal surface (water on top and air beneath) can go unstable and, whatever the flow rate, bubbles could form and bubbles could go up faster than the falling water could compensate. Once the total volume of bubbles is high enough, the pressure difference would go away and the upper leg would fall back into the top reservoir. It is easy to imagine it happening with a 1m wide tube and a 1m high siphon but not happening with a 1cm wide tube. But a lower reservoir would prevent this happening.
  • #51
I see :) I guess I'd be going in too deep if I ask where the instability comes from but this explains why a siphon would fail if the tube diameter is too big:D I'm wondering if this is a fundamental siphon rule or something that arrises from the particular fluids properties.
  • #52
Working or not depends on the total pressure difference between upper reservoir and lower reservoir. If the air were more dense, the siphon would fall faster, for a given height of water tubes. A more dense atmosphere would also mean that the maximum practical height of ∩ would be greater.
The operation of the siphon is governed both by atmospheric pressure differences AND hydrostatic pressure differences. I have a feeling that people want to choose between them.
  • #53
There is no 'restoring force' to make the horizontal surface go flat, after some random disturbance. So, once a dent forms, the water at the top part of the dent will flow down to the bottom, making the dent deeper etc. etc.
  • #54
Thats true I've been trying to choose for a while , but both play their roles I think it's just important to make a distinction where each is acting :)
  • #55
Just imagine a water siphon that's been set up in a deep (say a few hundred metres deep) tank of light oil. It would be easier to accept that both fluids will contribute to the siphon effect. For a start, the limit to the possible height for the siphon to operate would be significantly greater because the ambient pressure could be several atmospheres.
Here's a thought. Imagine setting up a saltwater siphon in a fresh water tank. The water pressure differentials would be very small.
  • #56
sophiecentaur said:
If the tube diameter is big enough ...
or the flow rate slow enough. What happens is water falls out of the tube and is replaced by air bubbles that travel upwards. Consider the case of a bottle of water with a 1 cm diameter opening: turn the bottle upside down and the water falls out, as air bubbles flow up through the water. Or consider the case of a garden hose with 1 cm diamter and zero or near zero flow rate. Take a section of the hose near the end and orient it downwards and you'll get the same results, water falls out, air bubbles flow up.
  • · Replies 17 ·
12K
  • · Replies 16 ·
  • · Replies 24 ·
  • · Replies 19 ·
