Blinked
- Messages
- 1
- Reaction score
- 0
Like what are the chances that dark matter can be described with electromagnetism instead?
None.Blinked said:Like what are the chances that dark matter can be described with electromagnetism instead?
I confess that this statement might have it's own flaws, but it manages to answer your question. If not satisfied with this one, just the second resource found by google (search for "dark matter" naturally) says:Dark matter is called dark because it does not appear to interact with observable electromagnetic radiation, such as light, and is thus invisible to the entire electromagnetic spectrum, making it extremely difficult to detect using usual astronomical equipment.
source: https://home.cern/science/physics/dark-matterUnlike normal matter, dark matter does not interact with the electromagnetic force. This means it does not absorb, reflect or emit light, making it extremely hard to spot. In fact, researchers have been able to infer the existence of dark matter only from the gravitational effect it seems to have on visible matter.
You seem to be asking, "can the effects attributable to "dark matter" be due to some sort of electromagnetic process instead?", am I right? A reasonable assumption, however very tricky observations of the splitting of spectral lines finds that the magnetic fields of galaxies are very, very weak, so unfortunately this idea doesn't seem to be supported by observations.Blinked said:Like what are the chances that dark matter can be described with electromagnetism instead?
None. The motion described by dark matter is measured by the light from stars. Bulky objects like planets and stars do not hold much electric charge per unit of mass.Blinked said:Like what are the chances that dark matter can be described with electromagnetism instead?
