How Does Theorem 4.29 Illustrate Continuity Issues in Inverse Functions?
Math Amateur
MHB
I am reading Tom M Apostol's book "Mathematical Analysis" (Second Edition) ...
I am focused on Chapter 4: Limits and Continuity ... ...
I need help in order to fully understand the example given after Theorem 4.29 ... ... Theorem 4.29 (including its proof) and the following example read as follows:
In the Example above we read the following:
" ... ... However, $$f^{ -1 }$$ is not continuous at the point $$f(0)$$. For example, if $$x_n = 1 - 1/n$$, the sequence $$\{ f(x_n) \}$$ converges to $$f(0)$$ but $$\{ x_n \}$$ does not converge in $$S$$. ... ... "My question is as follows:
Can someone please explain exactly how/why ... the sequence $$\{ f(x_n) \}$$ converges to $$f(0)$$ but $$\{ x_n \}$$ does not converge in $$S$$ ... ... implies that $$f^{ -1 }$$ is not continuous at the point $$f(0)$$ ... ... ?
-----------------------------------------------------------------------------------------------------------------------------------------------My thoughts ...
I think that the relevant theorem regarding answering my question is Apostol, Theorem 4.16 which reads as follows:View attachment 9239
If we let $$t_n \in f(S)$$ be such that $$t_n = f(x_n)$$ ... so the sequence $$\{ t_n \} = \{ f(x_n) \}$$ is in the domain of $$f^{ -1 }$$ ...
Then ... sequence $$\{ t_n \} = \[ f(x_n) \}$$ converges to $$f(0) = t_0$$ say ...
Then following Theorem 4.16 above ... for $$f^{ -1 }$$ to be continuous we need $$\{ f^{ -1 } (t_n) \} = \{ f^{ -1 } ( f(x_n) ) \} = \{ x_n \}$$ to converge in $$S$$ ... but it does not do so ...
(mind you ... I'm not sure how to prove it doesn't converge in $$S$$ ...)
Is that correct?
Hope that someone can help ...
Peter
  • Printed text from a textbook page showing Theorem 4.29 with its statement and the beginning of its proof, about continuity of the inverse of a one-to-one function on a compact metric space.
  • Printed page from a real analysis textbook: end of a proof, then an example with f(x) = e^(2πix) for 0 ≤ x < 1, noting f is one-to-one onto the unit circle but f inverse is not continuous at f(0).
  • Printed text of Theorem 4.16: a function f from metric space (S, d_S) to (T, d_T) is continuous at p in S if and only if, for every sequence x_n in S converging to p, f(x_n) converges to f(p), written as lim f(x_n) = f(lim x_n) as n tends to infinity.
Hi Peter,
Your idea is correct. Now, the sequence $\{x_n\}$ converges to $1$ in $\mathbb{R}$, but, as $S$ does not contain $1$, that sequence does not converge in $S$.
Intuitively, what happens is that, when a point $P$ travels counterclockwise in circles in $f(S)$, the image $f^{-1}(P)$ jumps discontinuously from $(1-\varepsilon)$ to $0$ in $S$ whenever $P$ passes through $f(0)=1$.
castor28 said:
Hi Peter,
Thanks castor28
Appreciate your help ...
Peter
