How does time derivative commute from one variable to another?
  • Context: Graduate
  • Thread starter Thread starter irishetalon00
The discussion revolves around the commutation of time derivatives in the context of analytical dynamics, specifically examining how derivatives transition from one variable to another. Participants explore the mathematical foundations of these derivatives, their implications in physics, and the definitions of differentials.
  • One participant expresses confusion regarding the commutation of the derivative from position vector r to its differential dr, referencing a specific equation from Meirovitch's text.
  • Another participant suggests that the time derivative of the velocity vector can be expressed as a differential algebraic variable, indicating that the scalar nature of dt allows it to be passed through the dot product.
  • A later reply emphasizes the need for a formal mathematical basis for understanding differentials, providing a one-dimensional example to illustrate the relationship between position, velocity, and acceleration.
  • Another participant discusses the definition of kinetic energy and its relation to time derivatives, introducing the concept of work done and its independence from the parametrization of a trajectory.
  • One participant presents a derivation of impulse with respect to time, noting that in most cases, mass is constant, which may influence the interpretation of the derivative.
Participants do not reach a consensus on the commutation of derivatives, as various interpretations and mathematical justifications are presented. The discussion remains unresolved with multiple competing views on the topic.
Some participants highlight the complexity of definitions and the need for a rigorous mathematical foundation when discussing differentials and derivatives. There are indications of assumptions regarding the constancy of mass and the nature of the variables involved.
irishetalon00
TL;DR
how does time derivative commute from one variable to another?
I'm reviewing Meirovitch's "Methods of Analytical Dynamics," and I don't understand the commutation of the derivative from r to dr:
\mathbf{F} \cdot d\mathbf{r} = m \ddot{\mathbf{r}} \cdot d\mathbf{r} = m\mathbf{\dot{r}} \cdot d\mathbf{\dot{r}}
irishetalon00 said:
TL;DR Summary: how does time derivative commute from one variable to another?
The definition of a differential that I use is:
If ##x = f(t)## then ##dx = f'(t)dt##, where ##f'(t) = \frac{df}{dt}##.
So, as ##\dot x = f'(t)## we have ##d\dot x = f''(t)dt##.
The result follows from this and an extension to the dot product.
  • Agree
Thank you PeroK. I think I got it. But to be sure, let me try to reiterate what you said in the context of my original question.
##\ddot{\mathbf{r}}## , which is the time derivative of ##\dot{\mathbf{r}}##, can also be thought of as being equal to ##\frac{d\dot{\mathbf{r}}}{dt}##, where ##d\dot{\mathbf{r}}## and ##dt## are differential algebraic variables. after making the substitutions, since dt is a scalar it can be passed through the dot product to ##d\mathbf{r}##, after which ##\frac{d\mathbf{r}}{dt}## is just ##\dot{\mathbf{r}}##
That's the hand-waving way to do it. If you want to justify it more formally, then you need a sound mathematical basis for what is a differential.
The first point to note is that a time derivative only makes sense if you can write ##x## as a function of ##t##. I'll use one dimension as it's easier on my phone.
If we have ##x = f(t)##, then:
$$(\ddot x )dx = f''(t)f'(t)dt$$And:
$$(\dot x)d\dot x = f'(t)f''(t)dt$$And we can see without any hand waving that the two expressions are equal.
That said, physicists wave their hands a lot, so you could just say it looks right and let the maths students worry about proving it!
In order for simplicity sake some authors make the narration harder.
By definition the kinetic energy of a particle is
##T=\frac{m}{2}|\boldsymbol {\dot r}|^2=\frac{m}{2}(\boldsymbol {\dot r},\boldsymbol {\dot r}).##
Thus we have
##\dot T=m(\boldsymbol {\dot r},\boldsymbol {\ddot r})=(\boldsymbol {\dot r},\boldsymbol {F}).##
The term from the right is called a power.
Integrating the last formula we get
##T\mid_{t=t_2}-T\mid_{t=t_1}=\int_{t_1}^{t_2}(\boldsymbol {\dot r},\boldsymbol {F})dt.##
The term from the right is called a work done.
If ##\boldsymbol F=\boldsymbol F(\boldsymbol r)## then the integral is an integral of a differential form ##(\boldsymbol F, d\boldsymbol r)## and thus it does not depend on a parametrization of the given trajectory.
The impulse of an object is given by $$ m\cdot v.$$ Derive this with respect to time: $$ \frac{d}{dt}(m\cdot v) = \frac{d}{dt}(m)\cdot v+m\cdot\frac{d}{dt}(v). $$ In most cases m is constant...
