How dose an angle of an object effect it's distance/
  • Thread starter Thread starter katie<3
    Angle
The discussion revolves around understanding how the angle of an object affects its flight distance, particularly in the context of a lab experiment involving an elastic band. Participants are exploring the relationship between launch angles and the resulting distance traveled by the object.
  • Participants discuss the optimal launch angle for maximum distance, with some suggesting 45 degrees as the ideal angle. Others express curiosity about the reasons behind this angle being optimal and seek background information on the topic.
There is an ongoing exploration of the relationship between launch angles and distance, with some participants sharing insights and resources. However, there is no explicit consensus on the underlying principles, and multiple interpretations of the problem are being considered.
Participants mention challenges in finding reliable information and resources related to their specific lab requirements. There are indications of spelling errors affecting search results, which may be a constraint in accessing relevant materials.
katie<3
Okay, so in science I have a lab I need to complete about how the angle of an oject will efect it's fligh. After a lot time shearching everywhere on the internet I have not found one single thing. The only thing close to what I was looking for was on this site. So I was wondering if anyone here could help me , or beter yet give me the address to a site which will have information on how the angle of an object will effect the distnce it travels.
Thanks,(sorry about the spelling :) )
-katie
just out of curiosity what grade are you in?
the angle with which an object is launched will determine how much of the initial velocity is in the x direction and how much is in the y direction
I am almost positive that it is 45 degrees.
what is:confused:
I'm in grade nine, but I'm in this weird program called IB.
But, we were given different labs out, and mine was "how does the angle of an elastic band effect it's disatnce". I've done the experiment, but I need to find background info. I have all I need for enegry but I can't find anythign on how angles would effect it. I know a bit myself, but not neraly enough to do the lab D:
Maybe I read this wrong. I was responding by saying that 45 degrees will give optimum distance.
In the textbook I used there was a page which clearly explained how the angle effected flight. I wish I still had it because I would scan it. Let me see if I can find something similar.
Yes, your right,but I don't know why. What I need to know is why that angle would be the best.
Sorry, D:
Thanks for your help<3
because of exactly what i said. read what i said and think about it.
Start with your horizontal and vertical equations for projectile motion, see if you can derive some relation involving distance or velocity as a function of launch angle.
e.g. can you derive [tex]d_H = v^2/g*\sin2\theta[/tex] ?
ok Katie, the reason y u can't find anything is bc u mispell everything u type in lol jk. I had the same project to do and i need resources. i got 2 and just need 1 more!
one more tip use the spelling check :)
The range (the distance the object will travel in the X plane) is optimum at 45 degrees. However, there are two angles for each distance less than that. Let me elaborate:
If you launch the elastic at 55 degrees, and at 35 degrees, they will end up at the same spot. The only difference is that 35 degrees will travel less high, but nonetheless they should end up in the same spot on the ground.
Same with 64, and 26 degrees. The two angles used must add up to 90 degrees.
  • · Replies 17 ·
16K
  • · Replies 29 ·
  • · Replies 26 ·
