How effective is a pocket car window breaker?
  • Thread starter Thread starter seazal
    Car Window
The discussion centers around the effectiveness of pocket car window breakers, particularly in emergency situations. Participants explore various aspects including the design, materials, and practical experiences with these tools, as well as considerations regarding tinted windows and reliability in critical scenarios.
  • Some participants question the effectiveness of pocket car window breakers, particularly when used on tinted windows.
  • Others share personal experiences, noting that such tools are effective on tempered glass side windows.
  • A participant mentions that the small contact area of these tools allows for breaking windows with minimal force, which can be crucial in emergencies.
  • Concerns are raised about the reliability of spring-activated tools, with suggestions that manual tools may be more dependable.
  • Some participants discuss the advantages of different types of hammers, including conical head hammers, for breaking windows in emergencies.
  • There is mention of a Mythbusters episode that demonstrated the effectiveness of these tools compared to other methods, such as kicking or using a hammer.
  • One participant proposes that materials like porcelain or industrial diamonds could enhance the effectiveness of impact tools.
  • Several participants express skepticism about the portrayal of window-breaking in movies, emphasizing that real-life scenarios differ significantly.
Participants express a mix of agreement and disagreement regarding the effectiveness and reliability of different window-breaking tools. While some share positive experiences, others raise concerns about specific designs and their practical use in emergencies. No consensus is reached on the best tool or method.
Participants highlight limitations related to the design and reliability of spring-activated tools, as well as the challenges of using larger tools in confined emergency situations. The discussion also reflects varying personal experiences and anecdotal evidence rather than established research.
This discussion may be of interest to individuals looking for effective emergency tools for vehicle escape, as well as those interested in the practical applications and limitations of such devices in real-life scenarios.
  • #31
[QUOTE="seazal,What are dark tint film usually made of? Is it also low strength polymer?[/QUOTE]
Nice ride. The newer Honda's are pretty sweet. Yes, in response to your question. The window tint, in relation to darkest "legal" terms has to do with the pigment load of the film.
As a general rule aftermarket films are significantly weaker than factory applied. The factory films and the very high end after market are done with a higher density film. This is to provide better scratch resistance and to reduce customer call backs only it is a more durable film but not higher density polymer. All of the window tints are a low density film. These films are applied on the inside of the window. If one attempts to break the window a punch style device or a hammer will work equally well. The Impact load in PSI is well over any of the film strengths in psi penetration resistance.
The earlier mentioned antennae trick will not work on the inside of the car if it is factory tint. Typically as a bystander one is on the outside of the vehicle and it will still work fine. The higher density film can sometime cause issues on the interior where the film is applied as it dissipates some of the impact.
Please be assured that the hammer or the punch will do great from either side of the glass. The film will tear easily especially once any break (even a crazed hammer hole) creates a stress riser.
This is all well and good if you are conscious and capable. If not, First, someone is coming in with whoever is there to be best buddy and observer. Second, that window is coming out even if one needs to bring 10,000lbs of hydraulic advantage.
Russ waters earlier post is also very relevant. The electric system works for a little bit even in the case of water submersion. The best answer is to just roll down the window if you can.
  • #32
  • #33
seazal said:
It glows in dark. Does it contain any radiation. Why does it glow in the dark?
No, it does not contain radiation. It is simple phosphorescence - the same thing that coats the inside of fluorescent tube lighting. The hammer's phosphorescent plastic is energized by exposure to any light source (such as sunlight).
seazal said:
In the orange or yellow the best glow color?
The one that doesn't clash with your car's upholstery. :wink:
  • #34
What is the lifetime of phosphorescent. Is it in the decade or a century? What is the average?
  • #35
Depends on the quality. There are many, many varieties.
You might ask the manufacturers directly, since they will know what materials they use.
Or simply Google 'how long do phosphorescent materials last' like I did.
Finding an 'industry-side average' is an exercise left up to the reader.
  • #36
The Lifehammer conical head manual hammer is three or four times more expensive than other brands. It advertised using hardened steel. Would the rest that used non-hardened steel would be less effective. Is there any effect between how hard is the conical head and how effectively it can break the glass?
  • #37
So there is no difference between the $14 Lifehammer conical head hammer and a $3 generic conical head hammer as long as the head is pointed? Because I'm tempted to buy the cheaper brands but wonder if they are as good as the Lifehammer which may be the first one ever built?
  • #38
As with all things, you get what you pay for.
Is it worth saving $11 (amortized over many years) to find out - when you're up to your neck in a lake and sinking fast - where they cheaped out?
Just a thought...
  • #39
Just a thought...
But theoretically.. is the metal head material composition when against brittle glass has any factor in breaking force?
  • #40
Couldn't tell you. But that's not the only way it could fail.
What if it's just aluminum?
What if it rusts in the years it's sitting in your console?
What if it just collapses?
You won't know until it's too late.
  • #41
Your asking a very good question. I do not have any studies to share but I do have some input and good anecdotal evidence.
First would be the configuration. Does each of the ones you are looking at have the same cutters and window spikes?
Second would What are your realistic plans for these devices? My first guess as to the cost difference is that the copies do not have the same heat treatment for the spikes and cutting edges. It is the sharpness of the edge and the very small radius of the spike that enable the forces to do what you want it for. Heat treatment changes the corrosion characteristics of steel. One could hide that for a while with a chrome plating but it will still corrode quicker and that can make a significant difference in sharpness.
In a related vein I have on more than one occasion demonstrated the antennae method and then passed off the antennae to another person to try and had them fail. Inspection showed that there was a significant flat on the soft metal ball created by my strike. They inadvertently used the same hand position and failed due probably to the increased area of impact. When I had them consciously rotate the wire it worked for them as well.
I guess my answer is close to the same as DaveC426913 You get what you pay for. If it will be protected and used once cheap is probably ok. If on the other hand you are going to stick it somewhere in the vehicle and ignore it until OMG having it work right out of the chute is a good investment.
  • #42
What is this 'antenna' technique several peeps have mentioned?
Only antennae I can think of are on the outside of the car.
  • #43
There are videos on youtube that show a great difference between the hard ceramic of a spark plug and other normal ceramics. So the hardness of the tip of the point can make a great difference. It should be harder than the glass. The punches used by firefighters have tips of hardened steel or diamond. Window glass is harder than the steel of a knife blade but not hardened steel. (Mohs scale: a knife blade, 5.5; window glass, 6.5; steel file, 6.5; see http://www.newworldencyclopedia.org/entry/Mohs_scale_of_mineral_hardness)
  • #44
You are correct, the antenna is on the outside. I think I mentioned it in the last paragraph of my first post ( # 28 of this thread I think). I use it almost as often as I do my punch. Here is a quick youtube of the idea,
FactChecker is also correct it is about the sharpness of the material and the ability of that material to stay sharp until the impact impulse is translated to the glass. I love my punch. Spark plugs are cool but not always available. A steel ball on an antennae is good about one or two tries but not always available.
Part of my reply to seazal is that if you are going to have all your eggs in one basket It is a good idea to hedge your bets.
  • #45
Ok. I was waiting for these clarification before buying the more expensive Lifehammer, and I'd order them now.
My worry is not about falling into river, but more of overturning or minor collision where the doors won't open because of jammed locks, and the windows are not broken. Here the conical hammer would be handy. Thank you all those who offer helpful tips.
  • #46
1. First rule is to always try to open the windows electrically (push button) when down in water. Because I can imagine people who in their eagerness to try if the Lifehammer work forget to try to open the windows by button first. Is there actual case of such.
  • #48
One thing also worth knowing - several modern cars are starting to come with laminated glass in side windows as well, not just the windshield. If you have one of those, a device like this will not help you, and will actually just waste time (and as Seazal said, always try rolling the window down first)
  • #49
Ay! I presume that they did something to mitigate the fact that broken, or cracked laminated glass has very sharp edges that can cut you to shreds. Perhaps the modified the glass formula, or perhaps they have a way for the window to pop out intact.
  • #50
Oh. I just bought 6 pcs of it. How do I know the side window is laminated or tempered? The model of the car is Subaru Forester 2016 and Honda CRV 2004.
  • #51
Call the dealers.
  • #52
That would be your answer. Very few cars have laminated side windows. The trend started appearing in 2017. The primary changer was that high end cars that were trying to improve the safety ratings needed better survivability in the difficult side impact tests. By using laminated glass the side curtain airbags had a durable surface to react against. The jury is still out on this practice as it is also known that it makes rescue more difficult and as anorlunda stated safety glass has sharp edges.
According to the vehicle manuals I have both of those vehicles are good for what you are planning. Many Fire and Rescue departments maintain manuals in the rescue truck that list characteristics of vehicles such as: type of glass, location of airbags, location of battery, anything the rescue types may need to know. The easiest way to find this info is to contact your local department and see if they have it listed. (The manuals are getting to be crazy so don't be disappointed if they are not current).
  • #53
It also decreases the probability of a limb (or an entire person) exiting the window during a rollover, which theoretically should improve rollover safety as well. As you said, it does hinder escape or rescue though, so it's not entirely a positive.
  • #54
cjl said:
...it's not entirely a positive.
...but probably a net positive. This thread focuses on escape, but it's the impact that kills most people, not the inability to escape a burning or sinking car.
  • #55
Just get some old spark plugs and remove the porcelain part, break into pieces and keep in the car. When you need it, just throw the pieces towards to windows.
I don't know where I know it from but it's good to know :) There are bunch of videos in youtube related to this.
  • #56
You're going to break a car window by throwing broken porcelain at it from a position sitting 6 inches from the window?
Huh. Apparently . you . are.
Seems to almost defy physics!
OK, so two questions remain for me:
  1. All the demos are from the outside, where there's plenty of room for a good throw. What happens when you are inside, strapped in the seat?
  2. All the demos use a freshly busted piece. What will happen with a piece that has been rattling around in your console for five years?
  • #57
They are also many videos of simply throwing salt at the side windows and it breaks. What happens here?
  • #58
Salt? Very interesting. I suspect that the salt, the porcelain the conical hammer, and the center punch all have two things in common --- a sharp point and hardness.
Salt crystals
  • #59
I think this stretches my skepticism to breaking.
I will put my money on 'fake' until convinced otherwise.
  • #60
Driving on winter roads, I have had salt hit my windows many times and it never broke any...
  • · Replies 40 ·
10K
  • · Replies 20 ·
