How Far is an Object Orbiting Earth if Its Period is 32 Days?
The discussion focuses on calculating the distance of an object orbiting Earth with a period of 32 days, using gravitational force and orbital mechanics. The key equations involved are Fg = G * m * Me / r² and T = 2π/ω. Participants emphasized the importance of converting the period from days to seconds and correctly applying the relationship between velocity and period. The final equation derived for the radius is r³ = G * Me * T² / (4π²), leading to a calculated distance of approximately 4.26e8 meters.
  • Understanding of Newton's law of gravitation
  • Familiarity with orbital mechanics and Kepler's laws
  • Knowledge of unit conversion, particularly time from days to seconds
  • Proficiency in algebraic manipulation of equations
  • Learn about gravitational force calculations in orbital mechanics
  • Study the derivation of Kepler's laws of planetary motion
  • Explore the concept of centripetal acceleration in circular motion
  • Investigate the implications of mass and distance in gravitational equations
Students in physics, educators teaching gravitational concepts, and anyone interested in orbital mechanics and celestial dynamics.
Digdug12
An object of mass 7.1x1023 circles the Earth and is attracted to it with a force whose magnitude is given be Gmem/r2. If the period of rotation is 32 days, what is the distance from the Earth to the object? Here G=6.67x10-11 Nm2/kg2, me=6x1024 kg.
Fg=G*m*Me/r2
T=2pi/Omega
I used the first equation to isolate r, the distance from the Earth to the object to get sqrt((G(m*Me)/Fg)=r
But this is where I get stuck, i don't see how to find the other unknown, Fg I'm guessing it has to do something with the period of 23 days, but I cannot connect the two in my head.
Hint: Apply Newton's 2nd law. How is the object accelerating?
I set it up so that Fg=Mac, since Ac=V2/r, but the radius is still in the equation. If substituted it back in i would have another unknown, velocity. What am i missing here? is there another force?
edit:
Should i use v=r*omega, Period=2pi/omega, and substitute v=r*(28/2pi) into the Fg=M(V^2/r)?
edit2:
i got the final equation GMeM/M(28/2pi)^2=r but its off by roughly 1x10^2., is there a problem with the period? I see that i used 28 days instead of 32 but i tried it with 32 also and it was still off, do i need to convert days into seconds or something?
Digdug12 said:
edit:
Good.
You messed that step up a bit. Redo.
ok so i setup it up to look like this:
Fg=m*r*(32/2pi)2
Then i substituted it back into the original equation and i got:
G*M*Me/M*(32/2pi)2=r
and this comes out to 1.87e10
the correct answer is supposed to be 4.26e8
Fg=m*r*(32/2pi)2
Still not right. For some reason, you are inverting things. v = r*(2pi/T), not r*(T/2pi). Redo your equation for v from post #3.
ahh thanks for catching that Doc. Al :D I'm sorry i still haven't solved it, I am really getting frustrated haha... i made the change in the equation but my answer is still off, is the mass in Fg=M*ac the mass of the object, right?
Right.
Show me your final equation.
for the first few tries i canceled one r on each side of the equation, it came out to be
r=G*M*Me/M*(2pi/32)^2
then i realized i was cancelling a r with a 1/r, so i carried the r^2 over and it became r^3, so i took the cube root of the answer, tried cancelling the M's, and still nothing.
The M's will cancel and you will need to take a cube root. What's the final version of your equation for r³?
Be sure to convert the period from days to seconds! (D'oh!)
oooo, sweet. thanks, I got it now :D thanks a bunch
  • · Replies 20 ·
