How Fast Can Neutron Stars Spin Before Losing Surface Material?
Neutron stars, formed from supernova remnants, can rotate rapidly due to their extreme density. To determine the maximum angular speed before losing surface material, one must equate gravitational force to centrifugal force at the equator. While some suggest calculating escape velocity first, others argue it's unnecessary for this problem. The key is understanding that at the equator, the gravitational force must balance the centrifugal force for matter to remain on the surface. The discussion highlights differing approaches to solving the problem, emphasizing the importance of force balance.
kim3648
Neutron stars are extremely dense objects that are formed from the remnants of supernova explosions. Many rotate very rapidly. Suppose that the mass of a certain spherical neutron star is twice the mass of the Sun and its radius is 5.0 km. Determine the greatest possible angular speed it can have so that the matter at the surface of the star on its equator is just held in orbit by the gravitational force.
First I would find escape velocity
https://www.physicsforums.com/latex_images/11/112728-0.png
And using that velocity as the tangent I could find the angular velocity? Is that a correct assumption?
Hmm, this problem is a little tricky in disguise. If matter at the equator is JUST held on my gravity, that means the object is ALMOST weightless. Use a force balance and set that equal to m*centripedal acceleration and then ask yourself what it means to be weightless. Where does that get you?
I think you have my question confused with that of the person below me !
That's interesting. I think you have your question confused with another one! No, but really...you can do your problem either way. It's just easier the way I said in my opinion.
It's not necessary here to find escape velo. The force due to gravity should be equal to the centrifugal force at the equator. The same as dwintz02 said.
He can't do it using escape velocity.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
