How fast is the surface area increasing
4 replies · 2K views · last reply
karush
MHB
The volume of a cube is increasing at a rate of $$\displaystyle\frac{10 cm^3}{\text {min}}$$
How fast is the surface area increasing when the length of an edge is $$\displaystyle 30 \text{ cm}$$
The answer to this is $$\displaystyle \frac{4}{3} \text{ cm}^2$$
$$V=x^3$$ and $$SA=6x^2$$ and $$\displaystyle\frac {dV}{dt} = \displaystyle\frac{10 cm^3}{\text {min}}$$
actually I don't know how to set this up relating $SA$ to $V$
Can you solve the SA equation for x? Then you can put that value of x into the V equation...
-Dan
-Dan
like thIs?
\displaystyle
SA=6x^2
\Rightarrow
x=\sqrt{\frac{(SA)}{6}}
Then since
$V=x^3$
\displaystyle
V=\left(\sqrt{\frac{(SA)}{6}}\right)^3=\frac{\sqrt{6}}{36}\cdot(SA)^{\frac{3}{2}}
karush said:
like thIs?
\displaystyle
SA=6x^2
\Rightarrow
Then since
$V=x^3$
\displaystyle
Another approach would be to use related rates:
$$V=x^3\implies\frac{dV}{dt}=3x^2\frac{dx}{dt}$$
$$S=6x^2\implies\frac{dS}{dt}=12x\frac{dx}{dt}$$
From the derivative of the first equation, we have:
$$\frac{dx}{dt}=\frac{1}{3x^2}\frac{dV}{dt}$$
Now, substitute for $$\frac{dx}{dt}$$ into the derivative of the second equation, and you will have $$\frac{dS}{dt}$$ in terms of $x$ and $$\frac{dV}{dt}$$ both of which are given.
$$\frac{dS}{dt}
=12x\frac{1}{3x^2}\frac{dV}{dt}
\Rightarrow
12(30)\frac{1}{3(30)^2}\cdot 10
=\frac{4}{3}\frac{m^2}{min}
