How Fast Was the Car Going Before Braking?
7 replies · 2K views · last reply
r26h
A car comes to a stop in 7.5 meters while braking at a rate of 2.0m/s each second.
A) What was the initial speed of the car?
B) What is the speed of the car after 0.5 seconds?
Final velocity = Initial velocity + acceleration*time
A) 0=Initial velocity+(-2)(7.5)
Initial velocty = 15 m/s
B)0=15+(-2)(.5)
Velocity=14m/s
r26h said:
A car comes to a stop in 7.5 meters while breaking at a rate of 2.0m/s each second.
Braking at a rate of 2.0 m/s each second sounds like a deceleration.
Did you check the units of this calculation? I don't think 2.0 m/s per second multiplied by 7.5 meters will give an answer in seconds
B)0=15+(-2)(.5)
Velocity=14m/s
A "breaking" car is on which goes to pieces. A "braking" car is one which comes to a stop using its brakes.
. Final velocity = Initial velocity + acceleration*time
This equation requires the stopping time; you are told the stopping distance.
Ok, so what if to find the time I did 7.5m/ 2s/m = 3.75 seconds.
Then used that equation:
0=Initial velocity + (-2m/s)(3.75s)
So the initial speed is 7.5m/s? Does that make sense?
I guess you mean 7.5m/(2m/s), but you must not go plugging values into equations just because you know an equation that wants inputs of that type. You have to think about whether the equation is appropriate to the circumstance. What standard equation did you invoke to arrive at that calculation? What do the variables in the equation represent?
Ok, I see my error. What if I used Vf^2=Vi^2+2ax, rearranged to Vi=Square root of (Vf-2ax)
=square root (0-2(-2)(7.5)
initial velocity=square root of 30 or about 5.48 meters/second
To find the time, next I used Vf=Vi+at
0=5.48m/s +(-2m/s)(t)
-5.48m/s==2t
t=2.74s
Then which equation would I use to find the speed at 0.5 seconds?
-5.48m/s==2t
t=2.74s
You are not asked for the time to stop, are you? But the equation you used will also tell you the speed after a given time.
