How feasible is home radio astronomy?
  • Context: Undergrad
  • Thread starter Thread starter Vanadium 50
The discussion revolves around the feasibility of building a homemade radio telescope for amateur radio astronomy. Participants explore various technologies, potential targets for observation, and the challenges associated with such projects, including technical expertise and equipment limitations.
  • Some participants suggest that advancements in software-defined radio (SDR) and the availability of satellite dishes could make homemade radio astronomy more feasible than in the past.
  • Others argue that the complexity of radio astronomy requires significant expertise and resources, making it less realistic for individuals to pursue effectively.
  • One participant proposes starting with easily observable sources like the Sun and gradually moving to more challenging targets such as Venus, Jupiter, and various pulsars.
  • Concerns are raised about the Sun's radio emissions being too weak during certain solar cycles, with some suggesting that Venus may provide better signals.
  • Participants discuss the potential of using interferometry with fixed antennas to detect celestial sources and the challenges of signal processing and noise reduction.
  • There is a mention of the need for careful consideration of the operating frequency, with some favoring the 21 cm band for its known sky structure.
  • One participant reflects on their past experiences with radio astronomy and the limitations faced when trying to detect weak signals.
  • Technical challenges related to data acquisition and storage are highlighted, particularly concerning bandwidth and processing capabilities.
Participants express a mix of optimism and skepticism regarding the feasibility of homemade radio astronomy. While some see potential in leveraging new technologies, others emphasize the significant challenges and limitations that may hinder individual efforts. No consensus is reached on the practicality of such projects.
Participants note that the effectiveness of homemade radio astronomy may depend on various factors, including location, equipment quality, and the specific celestial targets chosen. The discussion reflects a range of experiences and expectations regarding the capabilities of amateur setups.
Vanadium 50
Staff Emeritus
Education Advisor
Dearly Missed
TL;DR
Is a homemade radio telescope realistic?
There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs.
Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is noticeably more snow and static than when pointing it away from the sun (i.e. lines up with it). But I am looking to see what else can be done.
I imagine getting a couple of DishTV dishes, and mounting them in the corners of my house or yard,. This gives the directionality of a house or yard sized dish, but of course not the sensitivity. Ballpark a few degree resolution for the array (more like 30 for one dish) It is likely easier to point with phase than with motors. Use SDR as receivers, record every night to disk and "stack" days or weeks of exposure together. Because its SDR you can look, e.g. on and off the 21 cm peak and map out hydrogen.
I'm wondering - is there anything to see with something like this? The sun obviously, but I did that already. When I was maybe 10. Probably it is limited to night use, as the sun is so bright and an array of small dishes is not so directional. What;s the next brightest source? Jupiter probably. After that, Cassiopeia A perhaps? Is seeing the Crab pulsar possible? It's dim, but it also pulses at a known frequency - a Fourier transform should show a peak. I wouldn't need to discover it de novo - I already know its properties. (Unfortunately, it's in Taurus, which doesn't get terribly high in the sky)
Astronomy news on Phys.org
It is possible, but not realistic. There are better ways to invest your time and money.
The knowledge field is simply too big for one person, it requires a team. It takes electronics experience, numerical computing, and volunteer management, things that do not usually go together. The people interested in RA will be the amateur optical astronomers when there is cloud. For some reason, astronomers work best by themselves, alone at night. They self select. Good luck herding those cats.
Our Sun, during most of the solar cycle, is not as good a source as you might hope. Venus will radiate better signals more often. The best pulsars are in the southern sky, most people are in the Northern Hemisphere. To hear the brightest pulsar noise envelope in real time, you will need a 25-metre dish and a cooled receiver with a bandwidth of several MHz.
Position, position, position. If you live on a cliff above the sea, which is unlikely, you might make a "sea interferometer" with a single dish or a dipole array, then watch a radio source rise or set.
A steerable 15-metre dish, surfaced with wire mesh, is needed to get enough signal to be interesting. Cryogenic cooling a receiver is not simple, and eliminating the noise produced by switching power supplies, TV and microwave ovens will be difficult. An SDR is all mixer, so inherently noisy when you widen the bandwidth to a few MHz, to catch some astronomically small amount of energy.
HAM radio guys bounce signals from Earth to the Moon and back. If you cannot do EME, don't even think of trying RA.
Get creative. Find an unusual RA project, evaluate the cost of the engineering and building approvals needed for the antennas. Then think again. Rinse and repeat.
  • Skeptical
Let me push back a little.
I am not trying to compete with ALMA. I am thinking along the lines of the radio equivalent of Meade or Celestron. Real-time was never in the cards: but even amateur optical (Hi Russ!) stacks and processes the pictures - real time is not what it once was.
As far as expertise, the sketch looks a lot like the DAQ for a HEP experiment. Chosen because it is something I know something about. I know something about radio, and have done EME, although not with my own equipment. So while I am not an expert, I do have some expertise in relevant things.
This is going to be a learning experience, even if I did radio astronomy for a living, because it's got to be built out of what's readily available, which is certainly not goinng to be optimal. And that indicates a need for a progression of gradually more difficult targets - a gap of several orders of magnitude is difficult to recover from. Can one start at the sun, move to Venus, then Jupiter, then Cas A, then the pulsar in Vulpecula* and so on down to the Crab? Remember, real time is not an issue, but needing a month long exposure to see the sun would be. Nature has to be kind - you seem to be an expert - is she?
*Vulpecula? That's a real constellation? No named stars? It sounds to me like the IAU should declare it a Dwarf Constellation.
My first attempt to detect the Sun in about 1970 was a failure, even though it was active at the time. I have done my time keeping an RA observatory running, that was doing VLBI research. I have also tried to help an amateur RA group technically get it together. Maybe I am too honest, but there are limits to what can be done with such small signals. The Sun is simply too quiet most of the time.
You can build an interferometer from a fixed pair of antennas, then generate the sum and difference signals. Tune to a quiet RA reserved band, to detect Sagittarius, Cygnus, Cassiopeia, Canis Major, or Puppis, as they move through the combined beams of your interferometer. That may reward you with evidence of Earth rotation, and to show it was not terrestrial or solar, the length of the sidereal day.
  • Skeptical
Now we're getting somewhere!
My point was that if you need to span N orders of magnitude in sensitivity and you have 2N sources, it helps if they are roughly equally spaced (5 dB in my example) and there isn't a giant gap. Knowing the hierarchy of sources to target is therefore valuable.
In thinking of constraints...
I'm not going to clone Ariccebo. Even the NSF isn't going to clone Ariccebo. The question is whether it is possible to build something that is the radio equivalent of something between Meade/Celestron and the Cap'n Crunch Spy Scope.
So what's available - DishTV dishes are easy to come by, and the older C-band ones aren't much worse. (Although moving and shipping them is not cheap). However, if you want them on 1D mounts they get exepensive and 2D is even worse. Conclusion: "the earth is my mount" and use a combination of the earth's rotation and digital delay lto sweep the sky.
Operating band? The higher I go in frequency, the better my angular resolution gets, but the more expensive the radios become. I was thinking a relatively low 21 cm, because I know the sky has structure there. There is of course a lot of 2.4 GHz equipment on the market, but there's also a lot of interference, and even if there weren't, I suspect I'd just ghet a really good look at the atmosphere. SDR is one way to be able to experiment with different choices, within reason.
DAQ becomes an issue. If you think of a 21 cm receiver as a giant ADC, you will saturate the writing speed of an array of drives. And it will all be noise. The thinking was to trigger on differential signals (not exactly interferometry) above a threshold. This is a bandwidth limitation, but I can only afford so much. Bandwidth vs. capacity is the tradeoff with this design - the scale is 100 MHz is 1 disk/night. You need to either reduce the bandwidth, process the data immediately and free up the disk in time, or buy a lot of disks.
I am a bit surprised that you find the sun so hard to see when I found it so easy as a kid, but that was near the peak of Cycle 21. The sun has certainly quieted since then.
As frequency rises, the beam-width falls, and the dish needs to have a more accurate figure, with smaller holes, better steering and wind stability. It is difficult to make a sharp pointed thermometer at radio frequencies, without interference from Earth and satellite based sources. You need multiple channels with switching to separate the sources.
You must start with FET LNAs and band-pass filters before any mixer, or everything will intermodulate. SDR is not the solution, it is a problem.
There is no need to ADC at twice the bandwidth, unless you are doing VLBI when you only need two bits. Use a log-detector-limiter chip to detect the envelope power of each channel, low-pass and digitise the RSSI output. Something like a $10 cheap AD8307 on a PCB will do that job.
With pulse type interference, you may need to detect the minimum power, that then follows the cosmic noise floor, so rejects the interfering pulses. It works a bit like the old analogue TV noise blanker, where over-bright pulses are made black.
  • Skeptical
I don't understand that. Can you elaborate?
FWIW, @Drakkith first link uses SDR.
Um...OK. But it's not 1937, and we already have radio maps of the galaxy.
bob012345 said:
The first backyard radio telescope built specifically for radio astronomy was built by an ametuer named Grote Reber in Wheaton Illinois in 1937.
Reber was a qualified electrical engineer, who worked with J D Kraus, "Degauss with Kraus", de-gaussing ships in WWII. They discussed RA on breaks. Reber moved to Tasmania and lived at Bothwell, where he had an array of dipoles operating below 5 MHz, looking at cosmic signals, through "holes" that sometimes appear in the ionosphere.
SDR is the cheapest, which is why it is used, but that demo system does not do RA. When tested, it could not see the Sun.
"Unsurprisingly, the MRT also uses an RTL-SDR receiver for processing signals from the Low-Noise Block (LNB) in the dish. Professor Aguirre says that since they are still using the stock DirecTV LNB, the telescope is fairly limited in what it can actually “see”. But it’s good enough to image the sun or pick up satellites in orbit, which is sufficient for the purposes of demonstrating the basic operating principles of a radio telescope."
First; decide on the RA source you will view. Second; Given your antenna aperture, work out if it will be possible to extract a valid signal from the noise. Third; design your receiver chain. You need a wide-band receiver to capture sufficient energy for RA. If you are serious about RA, you will need something better than an SDR.
It is my observation that amateur RAs, who insist on using an item of equipment that they have now, lack the flexibility of mind and equipment essential to success in the difficult field. For a group, that effect is multiplied factorially.
Yes. He was brilliant. I have a book The Evolution of Radio Astronomy by J.S. Hey which states;
Radio astronomy would have lapsed into oblivion for a decade but for the inspired initiative of one man, Grote Reber, a young graduate radio engineer of Wheaton, Illinois, USA, who decided to pursue the research as a hobby at his own expense in his spare time.
I'm still not getting the "can't see the sun" part.
How bright is the sun? Well, there is something over 1 kW/m2 integrated over wavelength, peaking in the visible. Call it 500 THz, and say we are looking at 5 GHz. So we're down 100,000 in frequency. Cubing it to get power, and we're at a picowatt-scale into the antenna.
How sensitve are radios? Microvolts are typical, and since impedances are ohm-scale, microvolts mean mictoamps. So again, picowatts.
So even a quiet, blackbody sun should be visible within terms of order one. As the sun's activity increases, it should be even more visible - the sun is far more interesting than a blackbody.
Get yourself a copy of Radio Astronomy, John D. Kraus.
Chapter 8. look at the difference between quiet and disturbed Sun.
I will pick up a text before putting up an antenna, for sure. However, I am still unclear as to how people can miss the sun.
Is the active sun "louder" than the quiet sun? Absolutely. The plot shows it, and effects on the ionosphere are substantial. But the numbers I ran make it look like the sun can be seen even as a black body. It can't get quieter than that.
I'm willing to believe that the terms of order 1 that I didn't consider conspire to be large - there's a famous case where they work out to 192π3 (and I once ran into a case where it was 49152π6 - talk about bad luck!) but if that's the problem, I want to know that that's the problem.
If nothing else, it will push me to higher frequencies - you win on temperature (21 cm is quite cold), and you win on angular resolution. However, that also pushes the receiver cost up.
I've seen people post observations of the 1420 MHz hydrogen line a few years back using an SDR and an antenna made from a yard waste totter and aluminum foil. There is a decent Doppler spread across the plane of the galaxy. I'll rummage around and see if I can cough up a link or 2.
So, it's definitely possible to do. My recommendation is to steer clear of the cheesy 8 bit RTL-SDRs in favor of the slightly less cheesy 16 bit Sdrplay offerings. Much better RF frontends on them. It's a 20dB noise reduction straight off the bat. They are just 300 bucks or so a clean factor of 10 over the RTL-SDRs.
  • Love
Very creative and cool. :smile:
Drakkith said:
Interesting that the "hacakaday" site comes up. Seems to deal with quite a variety of technical topics. It's off the subject here (apologies) but there was an excellent article on net booting raspberry pies which is something I've been working on recently. Reference below if of interest.
https://hackaday.com/2019/11/11/network-booting-the-pi-4/
I’ve heard of using a 20m dipole to listen to meteor showers?
I guess if you are communicating about radio astronomy?
  • Haha
Here is a description of listening to meteor showers.
That does bring up an interesting question. How high up does on object have to be to be considered "astronomy". I'd say 100 km, but I am no authority.
That makes the aurora "astronomy", which may be undesirable.
Dish Antenna possibilities:
Satellite TV dish
a Snowboarding saucer. (roughly 2.5 feet dia., plastic, glue some Aluminum foil to it)
Spectrum magazine (IEEE publication) has an article about receivers/computers for same; (either October or November 2023 edition; I already tossed mine:frown:)
And an article on building your own system (with some links) at:
https://spectrum.ieee.org/track-the-movement-of-the-milky-way-with-this-diy-radio-telescope
And in case you have not already seen it:
https://www.physicsforums.com/posts/6940884
Cheers,
Tom
Home made radio astronomy systems can be built easily (and cheaply) using off the shelf components from Amazon or EBay, a computer, and if you happen to have one, a Wok ! The 21 cm hydrogen line is not difficult to detect with a system like this since the HI is distributed over much of the sky, and you don't need to worry particularly about where you are pointing - just point it upwards, and wait for the Galactic Plane to come roughly overhead. Oh, and don't forget to eat whatever you were cooking in the wok and clean it off first ... ! https://www.astronomy.com/observing/wok-way-to-the-stars-radio-astronomy-with-kitchen-gear/
Home radio astronomy is more than feasible: it's possible, cheaper than you think, and you can do more than you think. If you start with failure in mind, you'll get there every time.
A link to a presentation I gave at the Society Amateur Radio Astronomers (SARA) Western Conference this past April.
https://docs.google.com/presentatio...ouid=103956535943816132717&rtpof=true&sd=true
A link to the video of the presentation.
Excellent talk.
@Baluncore , who is an EE, was very very negative about SDR. You seem more positive. Care to comment?
You also keep coming back to H-1. What do you fnd interesting about cold gas? :smile:
  • · Replies 39 ·
  • · Replies 47 ·
21K
