How High Should the String Be Above the Floor to Keep the Sphere Sliding?
The problem involves a uniform sphere of radius r and weight W that slides along the floor due to a constant horizontal force P applied by a string. The task is to determine the height of the string above the floor, denoted as h, while considering the coefficient of friction µ.
  • Exploratory, Assumption checking, Mixed
  • Participants discuss the relationship between the angle θ, the height h, and the radius r, with some attempting to express sin(θ) in terms of h and r. There are suggestions to create diagrams to clarify the relationships involved.
Several participants are exploring different interpretations of the problem and the relationships between the variables. Some have proposed using trigonometric relationships, while others suggest simplifying the approach. There is no explicit consensus on the correct method or interpretation yet.
Participants are considering the implications of torque and the geometry of the situation, including the need to clarify the angles involved and their relationships to the forces acting on the sphere.
tartio
A uniform sphere of radius r and weight W slides
string. Suppose the coefficient of friction is µ. Find the height of the
string above the floor h.
ƩT = 0 because there cannot be non-zero torque as the sphere must not roll, as it is sliding.
T = r x F
Friction = μ*W
ƩT = 0 = T(P) + T(Friction)
= r x P + r x F(Friction)
= rPsinθ + rF(Friction)
= rPsinθ + rμW
=> -rPsinθ = rμW
=> sinθ = -(μW/P)
I have it to the definition of the angle of the force applied, but how do I relate the angle to the height above the ground?
T = r x F
Friction = μ*W
= rPsinθ + rμW
=> -rPsinθ = rμW
=> sinθ = -(μW/P)
What is θ? The force is horizontal, applied at height h above the floor. Make a figure . What is the torque of the force? ehild
I guess I'm not sure what you're getting at, since θ is the angle between r and P, and the torque is then r x P = rPsinθ.
But it got me thinking, if you take the θ between r and P and subtract it from 180 to get the angle that r makes with the horizontal to reach P (because of the parallel horizontal lines), I will then have an angle, say [itex]\phi[/itex] that can be used to describe the y position of the force. As in I will have the angle that relates to the "unit" circle. Then can I just take the sin([itex]\phi[/itex]) and add it to r to get the height? Would that work?
I suggest a drawing. In fact always do a drawing. I got a simpler answer with no trig functions.
Here is the picture I have been using. Maybe I'm interpreting the problem wrong?
Edit: Oh! Just saw your picture. Taking a look at it now...
Edit2: To reach your solution, did you use the same method, however? Rather, is my next step to find a way to rewrite the sinθ in terms of R and H or should I rethink my process?
Yes, try to write sinθ in terms of H and R. And check the signs of the torques -that of the applied force and that of friction.
ehild
I think I got it, hopefully this is right. Since the angle of θ is actually simply the angle that is made with the horizontal, as in a unit circle...
[itex]sin(θ) = \frac{-uw}{P}[/itex]
[itex]\frac{r-h}{r} = \frac{-uw}{P}[/itex]
[itex]r^2 - h = \frac{-uwr}{P}[/itex]
[itex]h = \frac{uwr}{P} + r^2[/itex]
No, your derivation is not right. What is uw? h is length, r^2 is length-squared. You can not subtract them.
The angle between two vectors is the angle enclosed by the direction of the vectors. See picture. You need the angle between the position vector R and the force vector P. Shift the position vector R, so as its tail is at the same point as the tail of P. θ is the angle shown. In the blue right triangle, you can see that sinθ = (R-H)/R.
The torque of the applied force should be equal in magnitude and of opposite direction as the torque of the friction.
ehild
Remembering that torque is just force * tangential distance, if you pick the centre of the sphere to sum them around you can read off the distances from the drawing.
The tangential distance for the friction force is just R
The tangential distance for force P is ?
EDIT: I modified my drawing slightly...
  • · Replies 18 ·
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 18 ·
  • · Replies 21 ·
