How is the acceleration of objects on an inclined plane determined?
The problem involves two objects of different masses connected by a string over a frictionless pulley, with one object resting on a rough incline. The scenario describes the motion of the objects when released from rest, focusing on determining the acceleration, tension in the string, and the coefficient of kinetic friction.
  • Participants discuss the relationship between the acceleration of the two blocks and the use of kinematic equations. There is an exploration of analyzing one block to find acceleration, as well as considerations of the effects of friction and the incline angle.
Participants are actively engaging with the problem, sharing their thoughts on how to approach the calculations. Some have suggested using kinematic equations, while others are questioning the assumptions about acceleration and the relationship between the two masses. There is no explicit consensus yet, but various lines of reasoning are being explored.
Participants are navigating the complexities of the problem, including the roughness of the incline and the need to consider forces acting on both masses. There is a mention of needing to derive equations that incorporate distance and time rather than just velocity.
leisiminger
Homework Statement [/b]
Objects of Masss m1= 4kg and m2 = 9kg are connected by a light string that passes over a frictionless pulley. Object m1 = is held at rest on the floor, and m2 rests on a fixed incline of 40 degrees. The objects are released from rest, and m2 slides 1 meter down the <b>rough</b> incline in 4 seconds.
a) determine the acceleration of each object using a kinematic equation for constant acceleration b) the tension in the string, and d) the coefficient of kinetic friction between m2 and the incline.
I'm really having trouble finding the acceleration, I'm not sure if I am looking too deeply into it.
Welcome to PF!
Hi leisiminger! Welcome to PF! :smile:
Is the incline a ramp that leads upward to the floor? :confused:
If not, can you explain the set-up?
Anyway, tell us what principles you've tried, and where you're stuck, and then we'll know how to help. :smile:
hi,
Thanks!
https://www.physicsforums.com/attachment.php?attachmentid=2614&d=1109446369
is a good picture of the problem, except that m1 starts on the floor at rest.
well, to be honest, i thought about just analyzing one block, since acceleration will be the same on both blocks, using a = Vf-Vo / t. Vf being .25 m/sec ( 1 m / 4 sec ), Vo being zero, and time being 4 sec.
Hi leisiminger! :smile:
I think you'll have to do an equation for each block, and combine them to get your kinematic equation.
Hint: call the acceleration a, and the tension T. :smile:
i don't understand, the acceleration of one block should be the acceleration of the other block right? The velocity of an object under constant acceleration will increase linearly and is:
vf = v0 + a t
vf = v0 + a t
oh I see what you're doing :redface:
yes, if you assume the acceleration, a, is constant, then you can calculate a without using m1 m2 or theta …
but you need an equation with s and t, not v and t. :wink:
any more help, just a clue?
oh come on
s = … ? :smile:
we use a,v,x,and t. i assume your mean x for change in distance? if so, its 1m
ok, i have an idea. would i use
a = m1g -m2gsin theta
m1 + m2
