How is the following operator linear?
  • Thread starter Thread starter tamtam402
    Linear Operator
11 replies · 5K views
tamtam402
How is the following operator linear??!
Is the following a linear vector function?
F(r) = r - ix
A function is linear if:
F(r1 + r2) = F(r1) + F(r2) AND F(ar) = aF(r)
F(r1 + r2) = (r1 + r2) - ix
F(r1) + F(r2) = (r1 - ix) + (r2 - ix) = (r1 + r2) - 2ix
According to me, F(r1 + r2) ≠ F(r1) + F(r2), but Mary L Boas says otherwise. What gives?
Well you would agree that f(x) = mx + b is linear, right?
But f(x1 + x2) != f(x1) + f(x2)
I'm not sure I understand your point? Yes, f(x) = mx + b is the function of a line, but it is NOT a linear function, since f(x1 + x2) ≠ f(x1) + f(x2). I'm not sure where you're getting at.
According to the Mary L Boas book, the operator I posted is supposed to be a linear operator, which means f(r1 + r2) = f(r1) + f(r2) and f(kr) = kf(r). My results show otherwise, since I find f(r1 + r2) != f(r1) + f(r2).
f(x)=mx+b is not linear.
OP: could you quote the entire problem. What is [itex]\mathbf{r}[/itex]? What is x?? What is [itex]\mathbf{i}[/itex] (I suspect it is just the first basis vector)?
Could it be that [itex]\mathbf{r}=(x,y,z)[/itex]??
i is the first basis vector, and r has been defined earlier in the book as (x,y,z), or ix + jy + kz.
I must be missing something, because it seems (according to your post) that r being (x,y,z) would change my solution, but I don't see how.
I still find f(r1+r2) = ix + 2jy + 2kz
f(r1) +f(r2) = 2jy + 2kz
You aren't distinguishing between the components of r1 and r2.
Let r1 = (x1, y1, z1), and r2 = (x2, y2, z2).
Now calculate f(r1 + r2) and compare that to f(r1) + f(r2).
Is this just a question about the multiple definitions of linear?
y=Ax+b is linear in one sense, and not linear in another sense, right?
Right. y=mx+b is the equation of a line in the xy-plane, so it's often called linear in that sense. It is not, however, linear in the linear algebra sense, which is what the OP's question is about.
F(r) = r - ix
What gives is that your x needs to be tied to your r, so if you have r1 and r2 you need x1 and x2.
RGV
You may want to write your F as
[tex]F(x,y,z)=(0,y,z)[/tex]
Do you agree that this is your F?? Do you see that this is linear??
To make it clear, I think the proper expression of your linear operator is this:
[itex]\underline F(a) = a - (a \cdot i) i[/itex]
which clearly is linear.
