How is the tangent and area inverse?
The discussion explores the relationship between the tangent to a curve and the area under it, emphasizing that the derivative and integral are inverse operations. It clarifies that integrals represent area under a curve but can also yield different units, such as displacement from velocity, which highlights the importance of understanding dimensions. The tangent's slope is distinct from the tangent line itself, leading to a nuanced interpretation of how slopes and areas relate. By conceptualizing distance as the area under a curve and rate as the derivative, the conversation illustrates how integrating the derivative accumulates total distance or work. This heuristic approach aids in visualizing the fundamental theorem of calculus and the inverse nature of these concepts.
member 392791
I've never been able to visualize how the tangent to a curve and the area under a curve are inverses of each other, can anyone give some intuitiveness to this?
I think the problem is that you are taking interpretations of the derivative and the integral (which are inverse operations) for those things, themselves.
Integrals can be understood as the area under a curve, but that doesn't mean that they are the area under the curve. For example, if you integrate the velocity of an object, you'll get its displacement. Displacement is in meters, not meters squared - so how does that jive with the integral as area under a curve? The answer lies in the fact that the "height" of the curve (i.e. the y-axis) is in m/s and the "base" (i.e. x-axis) of the curve is in seconds, so when you multiply base x height to get area, the units of time vanish and you get an "area" whose units are in meters ... This isn't as strange as it may sound at first. The key is that the idea of an integral as an area is an interpretation
ps. to make this clear: consider the language of your question, itself: you're identifying the derivative with the tangent, when in fact that isn't exactly the interpretation of the derivative commonly used. The derivative is the slope of the tangent line - not the tangent line itself. So the question would be re-phrased as "how are the slope and the area inverses", again they aren't really. Now if you think of y and x as both being measured in meters, then the slope as no dimensions (it's just a number) whereas the area has units of meters squared ... So in first case (taking the derivative) we start with meters and end with no units (just a number), but in the second case we start with meters and end with meters squared. Perhaps that analogy helps clarify how a slop and an area are "inverses" - ?
Distance = rate * time.
Distance is the total amount of stuff -- the area under the curve, the distance travelled, the amount of work done.
Rate is the derivative.
Time is how long you maintain that particular rate.
Now if the rate varies, you can conceptually divide the curve up into little pieces, on each of which the rate is pretty close to constant. Then you add up all the little d = rt calculations. In the limit, you're just integrating the derivative over an interval to see how much total stuff was accumulated (stuff meaning distance, work, area, etc.)
Does that help? I think you can spin that heuristic description into a proof of the FTC.
Think about the derivative as being approximately [f(x+h) - f(x)]/h and then think about the Riemann sum where for one 'rectangle' or 'strip', the area is calculated by h*[f(x+h]-f(x)]/h = [f(x+h) - f(x)]. If you add up all the strips you end up getting the familiar form F(b) - F(a) for the riemann sum, and f(x) for derivative.
Relativistic Momentum, Mass, and Energy Momentum and mass (...), the classic equations for conserving momentum and energy are not adequate for the analysis of high-speed collisions. (...) The momentum of a particle moving with velocity ##v## is given by $$p=\cfrac{mv}{\sqrt{1-(v^2/c^2)}}\qquad{R-10}$$ ENERGY In relativistic mechanics, as in classic mechanics, the net force on a particle is equal to the time rate of change of the momentum of the particle. Considering one-dimensional...
  • · Replies 49 ·
  • · Replies 53 ·
