How Is Work Calculated for Masses on a Stretched Spring?
6 replies · 7K views
vissh
Hi :D
1) Two equal masses (let a and b) are attached to the ends of a spring of spring constant k. The masses are pulled out symmetrically to stretch the spring by a length x over its natural length. The work done by the spring force on each mass is :
(a)1/2kx2 (b)-1/2kx2 (C) 1/4kx2 (d) -1/4kx2
I tried to solve in following way [may be wrong :)]
=> the force acting on 'a' and 'b' will be -kx . Dividing the displacement in 2 parts and thus, the displacement of 'a' or 'b' is x/2 from their initial positions. Considering one of the masses - let take mass 'a' :-
dW = -kx.dx [For any small displacement dx of 'a'] . So to get the total work done by spring , integrate dW from 0 to W and the right side from 0 to x/2 . I got W = -1/8kx2 .
But the solution in book says -1/4kx2 .
I think i am wrong somewhere can you please point it out for me .
Thanks in advance (^.^)
welcome to pf!
hi vissh! welcome to pf! :smile:
vissh said:
… Considering one of the masses :-
dW = -kx.dx . So to get the total work done by spring integrate dW from 0 to x and the right side from 0 to x . I got W = -1/8kx2 .
ah, if you're integrating from 0 to x, you must write ∫ kx.(dx/2) :wink:
(alternatively, if you let r be the right-hand displacement, you can write ∫ 2kr.dr, and integrate from r = 0 to x/2)
but even easier is to use the work-energy theorem, and just take half the energy! :smile:
=> the force acting on the each mass will be -kx. Dividing the displacement in 2 parts and thus, the displacement of each mass is x/2 from initial. Considering one of the masses :-
dW = -kx.dx .
x is the total amount of stretch in the spring, not the displacement of each mass. So: dW = -kx.dx is not correct. How would you write the displacement of each mass in terms of x?
Edit: Tiny-tim beat me to it!
Thanks for the welcome :D
First, I did some mistakes [in writing above],so can u see it again :D
Second,About my taking displacement of 'a' or 'b' to be 'x/2' :-
As i think , Let the 'centre' of spring [pt at equal dist from both sides] be the origin and 'a' is on left and 'b' on right. Let we pull a and b .When the spring is stretched symmetrically by x , both 'a' and 'b' moves by same distance on their respective sides.At the end ,'a' has moved by distance 'x/2' on left and 'b' by 'x/2' on right from their respective intial positions . Thus,an expansion of 'x' units in spring.
So,I think 'x/2' is the displacement of the 'a' and 'b'.
[if i did wrong , pls explain.I will love to hear it :D]
To tiny-tim :-
Hm The answer came right from the 2 ways you told .But how you wrote that ??[Can you pls explain :) I will love to see the explanation (^.^)]
And how can Work-energy theorem be applied on it ! There are two forces acting on 'a' or 'b' - one spring force and the other 'external force 'F' pulling these masses' .As 'F' is unknown How can Work done by spring could be found out o.O
Yes, x/2 is the displacement of each mass. But you didn't make use of that in setting up your expression for work!
You wrote: dW = -kxdx, which implies that the displacement is dx. As tiny-tim explained, the displacement is really dx/2.
You know (or should know) the energy stored in a stretched spring. That must equal the total work done by the spring. So the work done on each mass must be half that.
(^_^) Doc Al , Thanks a lot :D Got it now.
When there is further dx displacement in spring, displacement in 'a' or 'b' is dx/2 .
The elastic potential energy which get stored on 'x' comp or extension is 1/2kx2.
And this is also the magnitude of work done by the spring on the agencies at end points.
Thus,work done on 'a' or 'b' is -1/4kx2 as the work done got divided in two parts.
Did I wrote right this time ! :)
