How is x-vt a rightward moving wave?
  • Thread starter Jaccobtw
13 replies · 3K views · last reply
Jaccobtw
f(x-vt) = disturbance
The only way I can see x-vt being a rightward moving wave is if x-vt = some position the wave had initially. As t increases, x-vt gets smaller, despite the fact that it is a rightward moving wave. For example, if x = 10 m and v = 1 m/s, as t increases, x-vt describes a position the wave had in the past. Is this correct intuition?
It's a rightward moving wave for ##v > 0##. At ##t =0##, the wave takes the form of ##y = f(x)##. Choose a function ##f##. Something simple. For example ##f(x) = x##. Draw that initial state of the wave on a graph.
Then, for ##t = 1##, say, the wave takes the form ##y = f(x -v) = x -v##. Draw that state of the wave on a graph. Take ##v = 1## as well, so that ##y = x - 1##.
Has the wave moved left or right?
Another way of looking at this is from the standpoint of the wave.
For positive ##x## at a particular instant in time ##t## and at position ##x##, the function ##f(x-vt)## return a specific value, say ##3## units. Time always increases. At a later time ##t'>t## must ##x## increase, decrease or stay the same for the function to return the same value of ##3## units?
f(x) = 10 for t = 0
For t = 1, and v = 1
10-(1)(1) =9
We began at 10 and now we’re at 9, so hasn’t the wave moved to the left?
Jaccobtw said:
f(x) = 10 for t = 0
10-(1)(1) =9
That's not two graphs! This is what the graphs of ##y = x## and ##y = x-1## look like.
  • Handwritten graphs on ruled paper: upper graph of y = x through points P(0) and Q(0); lower graph of y = x-1 through points P(1) and Q(1), each with labeled x and y axes.
Another example: consider the function ##f(x)=x^2##, whose graph is a parabola opening upwards, with its vertex at ##(x,y)=(0,0)##.
For ##v=+1##, ##f(x-vt)=(x-t)^2##.
At ##t=0## we have the original function.
At ##t=1##, ##f(x-vt)=(x-1)^2##. It's still a parabola. Where is the vertex?
At ##t=2##, ##f(x-vt)=(x-2)^2##. It's still a parabola. Where is the vertex?
Note that, in general, if ##a > 0## and ##g(x) = f(x-a)##, then ##g(x)## is ##f(x)## translated to the right. One way to see this is to consider a point ##x_0## where ##f(x_0) = 0##. The corresponding zero for the function ##g(x)## is at ##x_1 = x_0 + a##. As ##g(x_1) = f(x_1 - a) = f(x_0 + a - a) = f(x_0) = 0##.
From this, we can see that the zeroes of the function ##g(x)## are the zeroes of the function ##f(x)## translated to the right by ##a##. And, everything else is translated to the right as well,
PeroK said:
PS I've shown two points on the wave (P and Q) at times 0 and 1.
Thank you, I think I’ve got it down. (x, f(x)) is where we want to find the disturbance. x-vt is the coordinate in the moving reference frame. It says, what is the disturbance at (x, f(x)) when the wave has moved a distance vt.
Perhaps, but ##y = f(x - vt)## is a function of two variables. You need either an animation, or to have an additional ##t## axis. Perhaps with ##t## going into the page. It's not enough, IMO, to try to think of a wave as a static function in 2D.
I’ll try to offer yet another perspective. The function ##f## describes the shape of the wave. We can consider a point on the wave with a particular constant value of ##f##, call it ##f_0##. Now consider how the point (or more generally, points) with this value are moving with time. We have ##f(x-vt) = f_0## so - assuming ##f## is locally invertible - we must have ##x-vt = c_0## for some constant ##c_0## such that ##f(c_0) = f_0##. Solving for ##x## we find $$x= vt + c_0.$$
Therefore, the ##x## value for which the wave takes the value ##f_0## increases (assuming ##v > 0##) with time. The wave moves to the right.
This somewhat repeats what has already been said, but there is an important underlying point that's maybe worth making explicitly...
Suppose you have any function ##y=f(x)## and some (say positive) constant ##a##.
The graphs of ##y=f(x)## and ##y = f(x-a)## are the same shape - but the graph of ##y=f(x-a)## is shifted in the +ve x direction by an amount ##a##.
(Correspondingly, the graphs of ##y=f(x)## and ##y = f(x+a)## are the same shape - but the graph of ##y=f(x+a)## is shifted in the -ve x direction by an amount ##a##.)
For example:
Three parabola graphs on shared axes from -3 to 3: y = x^2 with vertex at the origin, y = (x-1)^2 with vertex at x = 1, and y = (x-2)^2 with vertex at x = 2, showing rightward shifts.
If the ‘constant’ ##a## increases uniformly over time, this means the graph steadily shifts in the +ve x direction.
What if I phrase it like this: We want to find the disturbance at ##(x, f(x))## at time ##t## when the wave travels at velocity ##v##. Subtraction shifts the graph to the right. ##x - vt## is smaller than ##x## because it gives the coordinate where we want to find the disturbance in the moving reference frame.
Or, let the mathematics speak for itself. See post #12 by Steve.
