How large would the sun be if it were frozen?
  • Context: High School
  • Thread starter Thread starter dennis_n
    Sun The sun
The discussion revolves around the hypothetical scenario of the Sun being frozen, specifically exploring how much smaller it would be if its hydrogen and helium were in a liquid state. Participants engage in calculations, density comparisons, and the implications of gravitational compression on the Sun's size and density.
  • Some participants suggest calculating the volume of the Sun's hydrogen and helium using their respective densities to visualize its size if frozen.
  • Others argue that gravitational compression would significantly affect the density and volume, complicating simple calculations.
  • A participant notes that the average density of the Sun is greater than that of liquid hydrogen, implying that the Sun would compress under its own gravity if it lost its energy source.
  • One participant mentions that a liquefied Sun could be 2.7 times larger in diameter based on a specific density of hydrogen.
  • Another participant raises a question about the similar densities of Jupiter and the Sun, prompting further exploration of density variations within the Sun.
  • Some participants reflect on misconceptions about the nature of stars, particularly regarding their composition as gas and plasma.
Participants express differing views on the feasibility of calculating the size of a frozen Sun, with some asserting that gravitational effects complicate the matter. There is no consensus on the exact implications of density and compression in this hypothetical scenario.
Limitations include the dependence on assumptions about the state of matter and the effects of gravity on the Sun's structure. The discussion does not resolve the complexities involved in the calculations or the physical implications of a frozen Sun.
This discussion may be of interest to those exploring astrophysics, stellar dynamics, and the properties of matter under extreme conditions.
dennis_n
How much smaller would the sun be if all it's hydrogen and helium turned to liquid?
I can't figure out how to calculate this. But I thought it would be fun to visualize how much smaller in size a frozen sun would be compared to it's gas/plasma state.
Anyone?
Astronomy news on Phys.org
This should be pretty easy to compute. The Sun's mass composition can be readily found on the internet, as can the densities of liquid hydrogen and helium, which are the Sun's main components. Just take the masses of hydrogen and helium and compute the corresponding volume using the densities.
No, it isn´t.
Hydrogen and helium will be self-compressed by gravity.
White dwarf mass-radius relationships won´t help, either, because white dwarfs are carbon or heavier.
I thought that too, but then the gases change density from surface to core, so I thought a simple computation might not solve this.
snorkack said:
No, it isn´t.
But this was not the question as I read it. The question as I read it is just "if the hydrogen and helium were liquid of the typical densities, how much volume would it occupy". It is obviously not going to happen in reality.
You do not need the volume of the gases. You just need the mass.
The average density of the Sun is 1410 kg/m3
Liquid hydrogen has a density of only 70 kg/m3
Thus the Sun is already denser than liquid hydrogen would be.
If you were to remove the energy source that keeps the Sun from collapsing, it would compress until its core reaches a state of electron degeneracy. At this point you have the equivalent of a White Dwarf, and an object with a radius comparable to the Earth's.
I never thought to search for average density. It was faulty logic to assume that an extremely compressed plasma core wouldn't increase the average density to more than that of a liquid or solid state. Might be the public misconception that stars are mainly bodies of "Gas" and "Plasma" and we conceive both of these as very light, only experiencing gas as the air around us and thinking of plasma as an even more expanded form of it. Thanks! I learned something new today.
Weird.
So a liquefied sun would be 2.7 times larger in diameter. (Using Janus's hydrogen density)
I tried to figure out how big droplet of liquid He can exist.
By my estimate, somewhat smaller than Pluto, unless extra heating is provided. On account of the extra heating from relic radiation, a Pluto sized drop of He can be liquid without other heating.
So, how is it that Jupiter has approximately the same density as the sun?
1300 kg/m^3 Jupiter
1410 kg/m^3 Sun​
Asking for a friend.
I learned, by going down your rabbit hole, that I know way too little about how things work, on not-even-a-cosmic scale.
The sun has a larger variation in density. It's quite dense at the core and much less dense near the surface,
Here is a good article from NASA with a nice density vs radius graphs:
https://solarscience.msfc.nasa.gov/interior.shtml
  • · Replies 21 ·
  • · Replies 34 ·
