- 4,140
- 1,741
Yes that's right - it doesn't cancel out. Do you remember where you read that it does?
andrewkirk said:Yes that's right - it doesn't cancel out. Do you remember where you read that it does?
Cecil Tomlinson said:Any increase in velocity will shorten every locomotive, and somewhere down the line all remaining locomotives would have to exceed the speed of light for the train to stay connected. The train will suffer severe whiplash at some point. Does that make sense?
I don't think that's right. Here's why.Cecil Tomlinson said:infinitely long train could not accelerate because ... any increase in velocity will shorten every locomotive, and somewhere down the line all remaining locomotives would have to exceed the speed of light for the train to stay connected. The train will suffer severe whiplash at some point. Does that make sense?
rede96 said:The space that expands between any two space ships locally ( e.g next to each other) will always be very small and so if each space ships was constantly accelerating at the same rate as the local expansion, they would never grow apart. So in principle it is possible to have an infinitely long line of space ships separated by a 1 meter gap.
If this is not true, then which spaceship in the infinitely long line is not capable of keeping a 1 meter gap with the spaceship ahead of it?
andrewkirk said:But that gap doesn't need to be closed because the length of the 100 million cars, that was 3million km at rest is also shortened by the Lorentz factor, so that it is only 2.9million km, which is exactly the length of 100million cars. There is no gap.
andrewkirk said:It is not true because the further away from the centre point a ship is, the faster it has to move relative to its surroundings, in order to maintain a constant distance to the centre point. Far enough away from the centre point, that will require a spacelike velocity vector (ie 'superluminal' speed), which is impossible.
andrewkirk said:if the ship is indestructible (infinitely stiff and infinitely strong) it will be the first one that is a distance far enough away from the centre point that the surrounding stars are moving away from the centre point superluminally. That may be the distance called the Hubble horizon, although I may be mixing up my terms there.
Yes, if two observers are traveling at 0.6c relative to one another, each observes a 20% shrinkage in the dimensions of the other, including the distance between the atoms making up the other, but no shrinkage in their own dimensions or the distance between their own atoms.rede96 said:Am I right in thinking that the Lorentz factor is only for transforming between different frames of reference? E.g. there is no physical 'shorting' of any physical object to do it's speed through space time, or in other words the atoms that make up an object don't move closer together or 'shrink' due it's speed or acceleration?
It turns out I did mix up my terms. The Hubble Horizon is not the relevant measure. I think it's more likely to be the Event Horizon. Light from outside the Event Horizon will never reach us. This page describes the different cosmological horizons and their differences.There is one thing I read about light from stars that were outside our Hubble horizon would still eventually reach us as our Hubble horizon is growing.
