How Long Does a Bolt Fall the Last 28% of 85 Meters?
The problem involves a bolt dropped from a height of 85 meters, focusing on the last 28% of its fall. Participants are tasked with determining the time taken to fall this distance, as well as the speed at the beginning and end of this segment. The subject area pertains to kinematics and motion under gravity.
  • Participants discuss the calculation of the distance corresponding to the last 28% of the fall and the implications of neglecting air resistance. There are attempts to apply kinematic equations, with some questioning the definitions of variables and the setup of the problem. Others explore the relationship between the first 72% of the fall and the subsequent calculations needed for the last segment.
The discussion is active, with participants providing hints and relevant equations while exploring different interpretations of the problem. Some have made progress in calculating speeds and times, while others are still clarifying their understanding of the equations and the physical context.
There is uncertainty regarding the treatment of air resistance, and participants are navigating the implications of their assumptions. The discussion reflects a mix of approaches, with some participants successfully calculating certain variables while others express confusion about the relationships between them.
Gattz
A bolt is dropped from a bridge under construction, falling 85 m to the valley below the bridge. (a) In how much time does it pass through the last 28% of its fall? What is its speed (b) when it begins that last 28% of its fall and (c) when it reaches the valley beneath the bridge?
No idea.
I did .28 x 85 = 23.8 m. I also assumed g = 9.8 m/s^2, xinitial = 23.8, xfinal = 0, but I'm now lost. The five constant acceleration constants need v or t which I have neither.
No idea.
does the question require you to take air resistance into account? Or should I assume that it's dropped in vacuum?
I won't tell you how to solve it, but I'll just give you a hint and some relavent equations. (As stated by the forum rules, we don't do your homework for you.)
Hint: Draw a speed-time graph. Assign variables to the unknown numbers.
Relavent equations:
a = (v-u)/t
v = d/t
Good thing to remember: Always draw the speed-time graph or velocity-time graph if you're unsure on how to solve a kinematics question. (just a rough sketch of it will do, you don't have to draw it accurately on graph paper)
I believe I'm suppose to neglect air resistance. How could I draw a speed-time graph, if I don't have velocity or time? And what is "u" in the a = (v-u)/t equation?
Well, first you might want to figure out the information for the first 72% of the fall - that will help you get the starting velocity when the bolt enters the final 28%, and from there you can find all the other information you need.
Would a = -9.8 or +9.8?
Okay I did part b without doing part a if that is possible. First I flipped the problem upside down so the starting point is 0m and the bolt is falling up to 85m so that a = 9.8. I did v2 = vo2 + 2a(x-xo) to find v. So it's v2=0 + 2(9.8)(61.2-0). So v = 24.5m/s. That's part b.
But I'm confused on what part a is asking. Does it mean how much time elapsed during the last 28% of the fall or in my case the flight upward?
Acceleration is technically -9.8 because it's in a downward direction, but your method looks sound to me. I mean, the problem is asking for speed anyway; therefore, you don't need the negative sign to indicate direction, so you're fine - but just be aware that if you come across something similar asking for velocity, it would be negative.
And yes, part a is asking how much time elapses during the final 28% of the fall.
For part a I did x-xo=vot + 1/2at2. Plugging in I get
85-61.2=24.5t + 1/2(9.8)t2 to get 4.9t2 +24.5t - 23.8 = 0
Okay, that's nice, but when I tried doing quadratic formula, both my times come out to be negative. t = -1.32s and -3.68. What did I do wrong?
I'm thinking maybe you made an error with the quadratic formula.
My god, you are right, I made the answer to -4ac to negative. Ok so then the answer for a must be .8seconds. Does that sound too small? Also I found the answer for part c to be 33 m/s.
No, that all sounds about right. :)
Thanks so much physicsface! Great help!
