How long does it take the ray to traverse this path?
  • Thread starter Thread starter mba444
    Path Ray
The discussion focuses on calculating the time it takes for a light ray to traverse a path through a planet's atmosphere, where the index of refraction changes from 1.2 to 1.55 over a distance of 15.2 km. The initial calculation for the time taken in the medium yields approximately 1.779 microseconds, but the accuracy of this method is questioned. Participants clarify that the changing refractive index requires calculus for precise calculations, while the second part of the problem is simpler, as it involves the speed of light in a vacuum relative to the refractive index. Understanding the relationship between the speed of light and the refractive index is emphasized for both parts of the problem. Overall, the discussion highlights the complexities of light propagation in varying media and the need for careful application of physics principles.
mba444
A light ray enters the atmosphere of a
planet where it descends to the surface
15.2 km below. The index of refraction where
the light enters the atmosphere is 1.2 and it
increases uniformly to the surface where it has
a value of 1.55.
I) How long does it take the ray to traverse this path? Answer in units of s.
II) How long would it take to cover the same distance in a vacuum? Answer in units of s.
speed of light= 2.99*10^8
delta V = C/(delta N)
delta V= delta X / delta t
For Question I what i did is that
delta N = N2-N1= 1.55-1.2= 0.35
delta V = (2.99*10^8)/(0.35) = 8.54*10^8 m/s
delta t = 15.2*10^3/8.54*10^8= 1.779*10^-5sec
but I am not sure if my way is correct can someone please check and tell me if I am going wrong somewhere
and for II) i didnt understand what is needed therefore i didnt know how to attempt at a solution
need your help and thanks in advance
V1 = C/N1
V2 = C/N2
delta V = C( 1/N1 - 1/N2)
i didnt understand
Velocity in the medium = velocity of light in vacuum/refractive index of the medium.
So Δv = C/N1 - C/N2
is this a calculus-based course? because i think you would need to use calculus in a situation where the refractive index changes uniformly. as for the second part, it's much easier than you're making it. after all, the index of refraction is relative to the vacuum. for instance, in a piece of glass with index n=1.5, light travels 1.5 times more quickly in a vacuum than it does in the glass.
