How Many Logs Are Needed to Build a Raft for Four People?
To build a raft for four people weighing 80 kg each, the total weight of the passengers is 3139.2 N. Each log, with a density of 725 kg/m^3 and dimensions of 0.08 m radius and 3 m length, generates a buoyant force of 429 N. To achieve equilibrium, the combined forces of the passengers and the logs must balance, leading to the equation F(p) + n*F(l) = 0. By calculating the net force from the logs and the total force from the passengers, one can determine the minimum number of logs required. This approach ensures that the raft will float with the passengers just at the water's surface.
linemanpete
I have run into a problem and am completely stumped after. Help me before i pull my hair out.
What is the smallest number of whole logs (p (density) 725 kgm^-3) r= .0800m l=3.00m that can be used to build a raft that will carry four people each with a mass of 80.0 kg.
so using (pi*r^2*l)*725 i found the mass of each log to be 43.7 kg
BUt beyond this i run into huge headaches by trying to derive something that can include X # of 43.7 kg logs in relation to bouyant force and Weight
please help
The buoyant force on the logs is the weight of the water they displace and the condition of minimum buoyancy will be met if the logs are just completely sumberged with the passengers just at the surface of the water. All you have to do is balance all the forces (weight of the logs + passengers against the buoyant force).
Find the force generated by the 4 people on the raft, as well as the net force per log. That should set you on the right course.
I have some questions about this problem too. Okay, I've got that:
Force of buoyancy = Weight (of logs) + Weight (of load/people)
Since each person's mass was 80.0 kg and there are 4 people, I went
Weight (load) = (80.0kg) x (4) x (9.81m/s^2) = 3139.2 N (Force of the load)
and the force of each log is
(density of log) x (volume of log) x g = (725kg/m^3) x (pi) x (0.08m)^2 x (3m) x (9.81m/s^2)
= 429 N
But I'm not really sure what to do next...
Once you have the total force applied by the people on the raft as well as the net force created by each log (the difference between mg and the bouyant force), you need to find the number of logs that will make the force applied by the people + the net force of all the logs = 0
F(p) = force created by passengers
F(l) = net force created by each log
F(p) + n*F(l) = 0
Solve for n.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
