How Many Paces Did It Take to Measure the Gym?
  • Thread starter Thread starter ggcflo
The discussion revolves around a homework problem where a student measures the length of a gym using pacing, specifically with a pace factor of 0.78 meters per pace. Participants explore how to calculate the number of paces taken to measure the gym accurately to 1/4 of a pace, while addressing uncertainties and clarifications regarding the problem's parameters.
  • Homework-related
  • Some participants question the definition of 'pace factor' and clarify that it represents the distance covered in one pace, noted as 0.78 meters per pace.
  • One participant suggests that the length of the gym is 28 meters and calculates that 1/4 of a pace equals 0.195 meters.
  • Another participant expresses confusion about how to interpret "accurate to 0.195m" in the context of the problem.
  • There is a suggestion that the problem may depend on the actual length of the gym, with one participant proposing a length of 32.0 meters.
  • One participant provides a formula to calculate the number of paces based on a given length and pace factor, while also emphasizing the importance of rounding to the nearest quarter pace.
  • Another participant discusses the implications of rounding and suggests that the final answer should reflect the nearest quarter pace, leading to a potential discrepancy in the reported gym length.
Participants do not reach a consensus on the interpretation of the problem or the correct approach to calculating the number of paces. Multiple competing views and uncertainties remain regarding the gym's length and the accuracy required in the calculations.
Participants express uncertainty about the assumptions underlying the problem, such as the exact length of the gym and how to apply the concept of accuracy in the context of pacing measurements. There are also references to rounding conventions that may affect the final results.
ggcflo
a person tries to measure the length of a gym by pacing across it with a pace factor of 0.78. How many paces accurate to 1/4 of a pace do you think did the student make?
What is a 'pace factor'?
the 0.78 meters/ pace:)
Please show some attempt at this question so that others can see where you may be having difficulty. Have you included all the information given?
Doesn't it depend on the gymnasium length? What, 32.0 m? ggcflo, what is your gym length, in meters? If this problem is "really basic," as you stated in the title, why not answer it?
the length of the gym is 28. 1/4 of a pace is (0.78 x 0.25)=0.195.
how may paces accurate to 0.195m did the student make to get the length of the gym (28m).
28m x (1pace/0.78m) = 35.90 paces
the question I am having trouble with is how the part "accuarate to 0.195m"?
help and thanks again:)
ps: i thought the question was basic because it was on the first field exercise of my surveying 1 course..
welcome to pf!
hi ggcflo! welcome to pf! :wink:
oh i see! :rolleyes:
(ggcflo, in future, please give us the full question at the start)
i think it just means the equivalent of sig figs or decimal places …
instead of a result like 476.3 being rounded to 476 or 480 or 500, it wants it rounded to the nearest 1/4 :smile:
Surveying instruments are usually graduated in degrees and minutes (sometimes fractions of a minute) and it is usually possible to take a reading, estimating to the nearest quarter of a division on the scale. That is presumably why you are being asked to solve this problem at an enlarged scale, using paces; so that you can visualise what eventually will be a very small error. So please make sure you understand it. Another way you could get into the question is: What is the smallest and largest number of paces required to measure the length of the gym, and can you do better than that?
I forgot to add that in Shakespeare's time, the petty pace was a unit of time instead of distance. :wink:
From http://www.enotes.com/shakespeare-quotes/tomorrow-tomorrow-tomorrow" …
To-morrow, and to-morrow, and to-morrow,
Creeps in this petty pace from day to day,
To the last syllable of recorded time​
ggcflo: Try this practice problem, and see what value and units you get for length x.
L = length = 25.45 m
pace_factor = 0.78 m/pace
precision = 0.25 pace
x = round[(L/pace_factor)/precision]*precision​
By the way, always leave a space between a numeric value and its following unit symbol. E.g., 0.195 m, not 0.195m. See the international standard for writing units[/color] (ISO 31-0[/color]).
If the answer is 35.90 paces, then, to the nearest quarter, that is 36 paces, not 35.75 paces. Hence length = 36*0.78 m = 28.08m to the nearest quarter of a pace. Strictly, 28.08 + or - 0.5*0.195 But that gives an excessive claim to "accuracy". It needs rounding off. mmm...
  • · Replies 48 ·
