How many Photons per second are entering the pupil?
The discussion focuses on calculating the number of photons emitted by a 100-W lightbulb with a wavelength of 550 nm and determining how many photons enter a pupil dilated to 7.5 mm from a distance of 800 m. The calculations show that approximately 2.77 x 1020 photons are emitted per second. The correct approach to find the number of photons entering the pupil involves using the ratio of surface areas rather than volumes, leading to the conclusion that approximately 6.1 x 109 photons enter the pupil per second.
  • Understanding of photon energy calculations using the equation E=hc/λ
  • Familiarity with basic physics concepts such as light intensity and distance
  • Knowledge of geometric principles related to circles and spheres
  • Ability to convert energy units from joules to electronvolts (eV)
  • Study the concept of photon flux and its calculation through surface areas
  • Learn about the relationship between light intensity, distance, and area in physics
  • Explore the principles of geometric optics, particularly related to light propagation
  • Investigate the properties of light and its interaction with the human eye
Students in physics, optical engineers, and anyone interested in the quantification of light and its effects on human vision.
clamatoman
(a)Estimate the number of photons per second emitted by a 100-W lightbulb, assuming a photon wavelength of 550nm.(b) A person can just see this bulb for a distance of 800m, with the pupil dilated to 7.5mm. How many photons per second are entering the pupil?
E=hc/λ
h=6.63*10^-34 J s
c=3.0*10^8 m/s
1eV=1.602*10^-19 J
1 watt second = 100 joules
For part (a)
E=hc/λ=(6.63*10^-34 J s * 3.0*10^8 m/s)/(550nm) =3.616*10^-19 J
convert to eV: (3.616*10^-19 J * (1eV/1.602*10^-19J)=2.257 eV per photon
100 watt sec = 100 joules
(100 joules * (1eV/1.602*10^-19J))/2.257eV) = 2.77*10^20 photons
For part (b):
[/B]
Not excatly sure how to proceed. I made a circle and determined the percent of the circumference was the 7.5mm pupil then multiplied that by the total number of photons, but the answer I got did not mach the book.
C=pi*d=pi*1600m=5026.548m
(7.5mm/5026.548m)*2.77*10^20 photons = 4.13*10^14 photons.
The answer in the book is 6.1*10^9 photons.
How can I get to this answer?
Does a lightbulb send out all its photons in a plane?
Ah, I need to consider a sphere, and a conical section of that sphere with the circular base being the 7.5mm pupil. I shall attempt.
Volume of the sphere = 4/3 pi r^3 = 2.14×10^9 m^3
Volume of the cone = pi r^2 h/3 = 0.047 m^3
ratio = 2.196 * 10^-11
2.196 * 10^-11 * 2.77*10^20 =6.1*10^9 protons!
Thanks!
Actually, I believe that the given answer is incorrect. You want to look at the flux of photons passing through the surface area of the pupil per second, so the ratio should be between surface areas, not volumes.
Wouldn't that come out the same? The volume of a cone is proportional to the area of the base.
I think there is a conspiracy in this so that they come out the same.
The volume of sphere with radius r, $$V_s=\frac{4\pi r^3}{3}=S_s\frac{r}{3}$$
The volume of the cone with height r $$V_c=S_c\frac{r}{3}$$
From the above we conclude that the $$\frac{V_s}{V_c}=\frac{S_s}{S_c}$$ that is that the ratio of volumes equal the ratio of surfaces. The "conspiracy" is that both volumes can be written as the product of the respective surfaces times the same factor ##\frac{r}{3}##.
11K
